posted by Olsone on Dec 22, 2007
The "cancel off" button does not work so I can't shut the oven off. Also, the number "1" button does not work (actually the oven light tries to come on when I press "1". Everything else about the stove (including all of the other buttons) works fine.
Do you have any suggestions?
Thanks,
Erik
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 06, 2008
Hey Erik,
Thats was happening to my sisters jenn aire just a couple monthg ago. I ordered a board for it but, the daybefore it came in I jauseled the front of the board attachment piece and made sure all connections we're tight... yada... in the maint field... you know hand search all connections with these printed led boards you can just have a loose connections and send bad signals and false board readings. And yes, even touch pads willact weird. So good luck, worked for me!
Pete
Pete
Suggest a new solution for this problem
Post a New problem for Jenn-Air SVE47100 Slide-In Electric
Email this problem
Email this problem
Can you Help with these Kitchen Ranges problems?
Jenn-Air SVE47100 Slide-In Electric Kitchen...
Range is acting crazy
My range is turning off when it... Answer This...
bad thermostat
bad thermostat
You describe the thermostat as... Answer This...
My range cooktop scratch or...
When I clean my Whirlpool... Answer This...
model SVE47600oven light &...
the fan and oven light will... Answer This...
Lost object down vent in Jenn...
I have a 1972 Jenn Air Electric... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
Find Parts
