Question about Ovens
The inner glass for a Zanussi oven is missing. Is it possible to have this replaced?
  • 10,515 Answers
Has the inner glass come away from the metal inner door?
If yes, then there are two ways to do this.
The first is to buy a new inner door and fit it to your outer door.
The second is to get a tube of high temperature sealant and repair the existing door.
To repair it you'd have to take the door off the oven and take it apart. Easier than it sounds.
Once the door is off and taken apart, it's a case of take the glass off, clean the glass and the metal, apply the sealant, place the glass on top and then put a weight on it for 24 hours to set.
Then rebuild the door and refit it to the appliance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2009
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
Zanussi oven zbf 360 + bulb blows repeatedly
bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
Mar 24, 2017 | Zanussi ZBF360 Electric Single Oven
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
The inner pane of glass has smashed on our Zanussi ZBF 560 x single oven. I cannot find a way of either replacing the pane or the oven door as the hinges seem concealed Thanks
You will find some very helpful videos on how to do this by going to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter--- CLEANING OVEN DOOR GLASS or REPLACING OVEN DOOR GLASS,
You should be able to get all the imformatoin you need here.
Dec 02, 2010 | Zanussi Ovens
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
I broke the glass outside on the door of my Zanussi oven ZOB 646 QX model. The price of this glass together with the panal costs about 1/2 of the oven price. Can I replace this glass without buying the...
In my experience of repairing ovens, it is usually possible to replace glass without going to the expense of replacing whole panel.
Check with the manufacture.
Hop this helps.
Dec 05, 2009 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZBF 660 oven door requires removing to access replacement of inner glass
Hi BisseeCath,
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Oct 10, 2008 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
171 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
