Question about Maytag SDE3606A Electric Dryer
Changed power cord and grounded wrong wire, how much damage am I looking at here?
    President:
  • 1,776 Answers
There is really no telling how much damage was done, but hopefully it just blew the thermal fuse. It is located in the rear of the dryer and is usually attached to or near the exhaust duct. Use a multimeter or ohmmeter to check continuity. A lack of continuity will indicate a blown thermal fuse. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 04, 2009
3wire power cord to 4 wire cord dryer wont powe up
then you have got it wired wrong . check with volt meter which prongs are hot at the wall then make the matching ones to be hot in cord .two will not carry voltage but are ground or common earth
Feb 07, 2015 | Maytag Washing Machines
I have a 12 inch chraftsman table saw with 2 wires coming from motor. The wiring diagram inside the cap shows it to be wired for 240 how do I wire that thru a switch and to a three wire recepticle
Not quite sure what your question is - Are you trying to plug a 240 into a 110/120 outlet? Or are you trying to plug this into a 240 3 prong outlet?
Traditionally, table saws don't come with a power cord - you must supply one. Usually on the motor there is a metal plate that describes volts/amps/phase/hp etc. Get the Volts/Amps from this plate, then measure the approximate distance between your table saw and the 240 outlet. The gauge of the power cord depends upon the Volt/Amps and the length of the cord. There are many volts/amps vs length for wire gauge conversions on the net. I always get a bigger wire (smaller gauge) than what is recommended. Expect to pay $100 or more for the cord (don't be cheap here). If you have an under rated cord, you can start a fire, burn up your motor, melt plugs into outlets and have to replace the outlet (don't ask how I know).
I'm a little suspicious of the "white and black" wire from 240 - it's usually "white and red" with a "black" ground. 240 is made from two 120's - opposite sine wave. So black is usually the common ground, while the white and red are the two 120's. Volts between white-red=240, white-black=120, red-black=120. If you're absolutely sure that white-black=240, then you can just connect a ground wire to the motor case. Many home table saws can be wired for 240 or 120 - you need to make sure that you're hooking 240v to the correct wires. If you're uncertain at all, then don't do it.
I have wired 120 to a 240 motor by accident and the motor ran - it had no power and didn't spin at full RPM. You can damage a motor this way, so I wouldn't recommend it. I have never put 240 to a 120 motor - so I don't know what happens (guessing you could burn up the motor coils).
With all that being said, if you have 240 outlet with 3 wire receptacle, then just use a multi-meter to determine the 2 "hot" and the 1 ground. Volts from hot1-hot2=240, hot1-ground=120, hot2-ground=120. If you don't have a multi-meter, buy one (approx $12). Once you have it wired up, then try the motor by flipping the switch on then off again. If the motor didn't spin, then you did something wrong. If it hummed but didn't spin, you have some connections wrong inside of the motor. If it spins the wrong way, then your wiring inside of the motor is wrong (doesn't help to flip the wires on the outlet). If you blew a circuit breaker, then the wiring to the motor is wrong.
Sep 27, 2014 | Saws
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Q- how to rewire hard drive power cord
unless you know what you are doing, just buy another power supply
or, google "pc molex plug" and order a new on with pins, but you'll need a crimp tool for that job.
if you get it wrong, you WILL blow stuff up.
Feb 12, 2014 | Computers & Internet
When i hook up through the loop on my marshall head, connecting cables are being fried.
If you are frying cables that is bad! This means you have a bad ground loop.
IF that is an old Marshall head that doesn't have a three wire (with ground pin) power cord on it, take it in immediately to have a three wire grounding cord on it before you fry yourself and not just cables. Their old technique of having a switch to change to create a pseudo ground was stupid and VERY dangerous !
You can severely damage equipment due to bad grounds.
ALWAYS connect all interconnected electronics to the same power source or receeptacle.
Mar 22, 2011 | TC Electronic G-Major 2
When changing the cord from a 4 prong to 3 prong cord, the is no ground wire used?
Good day,
When going to the 3 prong the center or neutral wire serves as both the neutral and ground wire, It's important the grounding band be in place when performing the change to guarantee an effective ground.
Look here.
This is the 4 wire system, here is the 3 wire.
Notice the marked ground strap. It must be in place.
Jun 03, 2010 | Whirlpool LEQ8000JQ Electric Dryer
My power cord on my WM2016CW washer melted to the back of my dryer and shorted out the dryer!
hi,
if your handy , you can fix that. first see if you can get the dryer going again. unplug everything and use a pair of wire cutters to remove the damaged cord off the dryer , make sure all that damaged wiring is unplugged and away from the dryer and plug your dryer back in and reset the circuit breaker and try the dryer. hopefully its okay. then unplug everything again, pull the washer out and look where the damaged cord goes into the machine, the back of the washer may have to come off. remove the strain relief fitting by turning a quartewr turn clockwise, remove the ground wire and remove the wires off their posts carefully. look carefully at the cord for a ridged end of the cord or writing on the cord this is your neutral side of the wire, make sure when you replace with the new cord the wiring is exactly the way it was on the old cord. reorder the cord from the sears parts store and hopefully that gets you going. if things are worse than this or you have any doubt, call the repairman..jm
Dec 27, 2009 | LG WM-2277HW Front Load Washer
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer works but no heat. We just moved...
most likely there is something wrong with the way the cord is wired to the machine or the outlet is dead. Dryers dont usually get damaged just by moving them. did u change the power cord. red on one end white in the middle black on the other end and green to cabinet ground.
Jun 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
Maytag SDE3606A Electric Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
