Question about Dewalt Heavy - Duty 10" Wet Tile Saw - D24000
Tile saw began having trouble starting. I would
Tile saw began having trouble starting. I would have to "jiggle" the blade and then it would start. It seemed like it was losing power though and the rpms would go up and down. It really bogged down making a cut and then the power just slowly died out (kind of like a car running out of gas). Now dead.
  • 120 Answers
Your motor brushed sound like they're gone bad. Some electric motors have two small plugs on the side which house the brushes. See if yours has this and get new parts. The other possibility is that the bearings are corroded and has built up enough resistance to stop everything.
Might not be able to replace those, however.
Posted on Oct 14, 2009
I have a QEP 7" tile saw. When I plug it in and press the switch, it hums-blade does not spin. (Note: not ready to cut tile yet, so no water in the bottom) Does anyone have any ideas on what's wrong?
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
Feb 12, 2016 | Qep Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
How do i adjust the alignment of blade on Dewalt wet saw
That's easy to do it , all you have to do is lose three screws on the left side of the track. There are four screws, on each track, you have to start from the front to the back. Don't lose the Last one. The four one. Then there's one screw under of the rails. going horizontal. It's going to be in your left side. You have to do is just screw in. Ifyou want to open it. Screw it out if you want to close it.
Sep 29, 2012 | Dewalt D24000S HeavyDuty 10inch Wet Tile...
Target wetsaw starts and runs fine. Half way through the tile the blade binds and the motor bogs down which trips the breaker. It does it every cut now. Never had an issue before. Tightened the belt, still...
First thing I would check is that the table is square to the blade. If the back edge of the table that pushes the tile through the blade isn't perpendicular to the blade the cut will start fine but as you go through the tile the table will be pushing the tile into the side of the blade and cause a huge amount of friction, making the motor work harder and eventually pop the circuit breaker.
Jan 21, 2011 | Husqvarna Saws
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
MK101 won't start
Can you move the blade with your hand or does the blade not move at all or is the sound buzzing even with the blade spinning cuz mostly this sounds like the blade is stuck and should be able to free it by moving it by hand unplugged all the debris from the tile dust can lock up the blades sometimes if it is not cleaned properly
Jun 20, 2009 | Mk Diamond Wet Saw with Stand
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Dewalt Heavy - Duty 10" Wet Tile Saw - D24000 Logo
314 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
