Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Legend pool cleaner wheels not moving
I have 3 year old Pentair Legend pool cleaner. Booster pump is working, backup valve working(legend is getting water flow), but the wheels are not turning, it just sits there except when backup valve cycles.
  • 990 Answers
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
Pentair legend platinum pool cleaner won't back up
Do you have a Back Up Valve?
It will be about 3' away from the unit.
if you do, then backup valve has failed, needs replacement.
Or... You can just replace the internal gear assembly.
It looks like this, follow the link...
Amazon com Pentair backup valve
Sep 30, 2013 | Pentair White/Gray Legend Platinum...
Pentair legend pool cleaner gets stuck
make sure back up valve is working if not replace
Feb 07, 2013 | Pentair White/Gray Legend Platinum...
Pentair Legend with boster pump dosent stay on bottom of pool. Seems to float near top of pool more than it does staying on bottom when its suppose to be cleaning.
Make sure that your wheel RPM is not greater than 32. If the RPM is too high, the cleaner will be forced from the bottom of the pool. Make sure that your back up valve is cycling properly because it, too, can cause the cleaner to lose contact with the floor. You might need to use a diverter to make sure that the pool cleaners not getting too much pressure.
Feb 28, 2011 | Pentair White/Gray Legend Platinum...
My great white pool clearner is not moving in the pool what might be the problem?
There are several thing that you can check. Be sure that both the filter pump and booster pump
are on and working properly. They might need to be cleaned. Also, check the wall fitting screen for debris and rinse clean. Test your pool cleaners wheel RPM and make sure that it is in the desirable level of 28-32. Make sure that your back-up valve is cycling. Check all the hose connections and
swivels for leaks that can cause loss of water pressure.
Nov 22, 2010 | Pentair White/Gray Legend Platinum...
Our Pentair Legend moves to a wall and stay there
Yes place the left jet (it rotataes) to the 11:00 position and the right jet to the 5:00 position and it will run correctly.
The Pool Tech
Jun 28, 2010 | Pentair White/Gray Legend Platinum...
I just moved into a house with a pool and i hook up the legend and it doesn't crawl
If these pool cleaners are moving, there are several suggestions in the users manual. I have attached a copy below in case you didn't get one when you took the pool over. Basically, make sure that your filter ,booster pump, and wall fitting screen are all clean and working properly, check wheel RPM and get it to 28-32 RPM, make sure that your backup valve is cycling, and check all of your hoses and connections for leaks or cracks that would allow air into the line.
http://www.poolcenter.com/Platinum_Manual.pdf
Jun 15, 2010 | Pentair White/Gray Legend Platinum...
Our three year old Legend keeps tipping over while
Sounds like the head float just below the debris bag is bad. Check to see if it has water in it. If so then replace it. That float helps keep it upright.
May 23, 2010 | Pentair White/Gray Legend Platinum...
The backup valve is not working and appears to have a clasp missing on the cog wheels. Where can I find a detailed schematic of the internal parts?
There is no schematic available. They don't sell replacement parts fot the backup timer either. Your best bet is to replace it.
Dec 22, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
673 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
