Question about Refrigerators
Pilot light will not stay lit on royal dometic frig
  • bakerstowing Oct 04, 2009
    there is a sloted hole before pilot light which has propane going thru when pilot is lit while holding lever
    thank you very much good advise
  • 10,515 Answers
The most common solution to the problem you are describing is removing taking apart and cleaning the pilot assembly. It is common that a pilot will stay lit with a marginal flame until the burners come on this creates a draft as the burners begin to vent and draws the soft inadequate pilot flame away from the thermocouple.
If problem still persists, you need to change the thermocouple.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2009
Pilot light on my heater keeps going out an I have a hard time lighting it. It's a Royal Jet serial no. Is 55FG385412 Model FG355 help if u can
Get the pilot light sensor replaced as the burn down with use and if they are just out of spec the sensor cools and shuts off the gas flow for safety
Dec 05, 2015 | Dayton Gas Furnace Heater
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
On my dometic refrigerator, modle# rm36e, prod # 9264530, ser # 7090209 the piolt lite will not stay on when I let go of the button
Just like with any older pilot light gas appliance, your refrigerator has a thermocouple which senses heat from the pilot and sends an electrical signal to the pilot valve when it is properly lit. I suspect this thermocouple has gone bad. It will look like a probe sticking into the area of the flame from the pilot and will unscrew from some sort of mounting bracket and have a wire on the other end that plugs into a connector. Generic versions may be available at home appliance repair centers but original replacement would be the best choice. RV repair centers and supply stores will carry it. Do an online search for RV repair supplies or more specific search for Dometic repair centers.
Apr 04, 2012 | Refrigerators
Gas shuts off after 30 seconds
first try fitting a new thermocouple,its the short 1"stick that keeps the pilot lit....
Jun 02, 2010 | Dometic RM2620 Refrigerator
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Model 211 Dometic, can not keep pilot lit, do I have to have it hooked up to 12 volt
Dometics work on propane, 12 volt or 110 volts, if pilot won't stay lit then you prob have a control board defective. Apply 12 volts and see if pilot stays lit, then you will know.
Oct 16, 2009 | Dometic Refrigerators
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Will not stay lit
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Jun 29, 2009 | Dometic RM2852 Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
