Question about Car Audio & Video
I am getting an error code 3 from the CD player on my 2003 audi A4 symphony radio. The radio and cassette are fine.
  • 1 more comment
  • Randy Jacobson Oct 04, 2009
    I totally powered the system down including pulling it out to check the connections again. Still not working. I get a NO CD message then the Error Code 3. It will not LOAD a new CD either (the red light doesn't come on).
    Randy
    I am getting an error code 3 (unit malfunction)from the CD player on my 2003 audi A4 symphony radio. The radio and cassette are fine.
    Solution #1 posted on Oct 04, 2009
    Rank: Guru
    Rating: 87.85% , 125 votes
    A fix that often works for this problem is to pull the fuse for the radio from the fuse block out and leave it out for 10 minutes or so and then re-insert... HOWEVER, make sure you have the radio's security/unlock code handy because it will reset this and you will need to re-enter it after you re-insert the fuse and power the deck back up.
    Comments:
    Oct 04, 2009 - I totally powered the system down including pulling it out to check the connections again. Still not working. I get a SLOT EMPTY message then the Error Code 3. It will not LOAD a new CD either (the red light doesn't come on). Randy
  • Randy Jacobson Oct 05, 2009
    Rylee,
    The OBU tool solution is well beyond my understanding. I submitted the problem to the Audi owner help line and they came up with a somewhat risky but effective solution:
    "If you receive and error code 3 and there is a CD inside you can use this procedure. !IF the radio is out of warranty, you can remove the radio (using the Audi/VW radio removal tools), move to a clean, well-lit location and remove the 2 gold screws at the rear of the unit. Gently lift the black top panel, it has all the unit identification number and inspection sticker (factory seal will break). Observe the CD load mechanism and any visible CDs. Check to see if there is an obstruction or the CD is tilted. If the CD did not load properly, gently press on the upper part of the cd until it aligns it self. Inspect the unit and replace the black top panel. Reconnect the power and stereo connectors. Turn the unit on and press and hold the eject button. If this resolves your problem -excellent-, if not pull the unit and check the CD. If it is tilted you have a bad feed and will have to repair or replace the unit. Audi A6 fan"
    I was able to perform the repair and the unit is working perfectly. I think it was a bad CD (hopefully). I put a old CD (one I didn't mind losing) in and it seems to work. Please feel free to pass this on. As I said it is risky but seemed to work.
    RJJ
Error code 3 is a jammed/incorrectly installed disc. Apparently if you pull the fuse and leave it out for a while, the stereo will reset itself. Make sure you've got your security code for your radio before you pull the fuse.
Posted on Oct 05, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code 3 on Audi A4 radio occurs due to a jammed/incorrectly installed disc. Try and press eject button for 10-15 seconds to clear the error code.
If this doesn't resolves your issue then use an OBD tool and try to reprogram the radio with the software using the OBD tool.
Please see this link for more details--
Audi A4 radio error 3 code removal
Folow the step by step instructions.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 04, 2009
  • 285 Answers
What is the power button on the radio on 2001 Audi Quattro tt stereo?
User's manual of your car should have a schematic indicating On/off button else, try different buttons. One of them should turn your device on,
If you can't find any button which might turn your radio on, probably it is bad, not working.Return it to shapo and claim your warranty
Nov 08, 2015 | OEM 2001 Audi Allroad Quattro Radio / CD...
How can i get the radio code for my audi a4 2003 if you can help me please thank you
pull your radio out of the dash and get the numbers off it and call your dealer
Jul 16, 2015 | 2003 Audi A4 Cabriolet
What is the radio code for my audi a4 2000
No one in the world would or should know someones
radio code
Should you know the codes of all your neighbors car radios?
Ask a dealers parts dept or service mgr for help in getting & installing the code
May 15, 2014 | 2000 Audi A4
Need audi A4 radio code
this radio will need coding to the car, you will have to take it to Audi.
Dec 07, 2009 | Car Audio & Video
No sound from 2004 Audi A4 factory stereo
You just go to the link I attached I'm sure you will get the solution of your problem
2004 Audi A4 Workshop Repair Service Manual PDF Download
Sep 06, 2017 | 2004 Audi A4
Symphony radio goes soft and looses bass at high volume
all that is, is the speapers cant handle the sound
Jul 08, 2009 | 2004 Audi A4
I get a ERROR 1 code on my audi Bose symphony radio. The CD player will not work. The tech bulletin dated 9/16/04 has a notice that says clean the disk. If that doesn't work, it says replace the radio! Is...
i had same problem with 01 a4 bought from arnold clark .kicked up a fuss and they got it repaired for me, this was nearly 2yrs ago and it's been perfect since so i would say all you need is good audio engineer. by the way audi also told me the radio needed replaced
Mar 18, 2009 | 2001 Audi A4
You could try a laser lens cleaner (the one that looks like a CD with little brushes on it) to see if that'll do it. There's no guarantee that the problem is with the laser eye though. If it is (such as just being dirty or dusty) then this may do it. If not though, that error code may indicate a more permanent failure of the head unit.
Jul 25, 2008 | 2001 Audi S4
Car Audio & Video Logo
2,992 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
