Question about Boating
Suzuki outboard DT 140 tilt trim switch worked fine the other day .now it wont do anything no noise or movement or anything
    Problem Solver:
  • 12 Answers
Check all wire connections, Check switches at binical and at pan on engine. Bill
Posted on Oct 08, 2009
Suzuki DT40CR Outboard stuck in down position
There is a hydraulic "unlock" screw somewhere on the side of the power trim reservoir.. usually easily accessible with a flat blade screwdriver... just turn it out about 3/4 - 1 turn.. no more... this will bypass the system and allow you to pull up your outboard.
Jun 06, 2017 | Suzuki Cars & Trucks
Suzuki4stroke 150 hp will not start, new battery gets juice just clicks
starter solinoide sounds like it failed if its clicking ! remove engine cover and as a friend cranks the key listen where the click is and it will have the +wire from battery and then a wire to starter , check connections are tight and if all ok then replace solinoide !
Sep 07, 2014 | Suzuki Tilt Trim Motor, DT 150-200...
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
Suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Dec 02, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Tilt trim go up wont go down 2003 johnson 140 hp 4 stroke
You may want to check service bulletin #2002-052. Some of these motors supply too much voltage to the trim switch at the throttle lever and that trim switch stops working. There is an add-on harness #586806 that fixes this. If you can still tilt and trim the motor at the trim switch that is built into the motor housing this is likely the problem.
Jan 30, 2012 | Boating
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
My 1978 140 evinrude electric trim tilt motor working but wont lift or lower happend suddenly after it lifted.maybe the pump?
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
Jun 06, 2009 | Boating
Boating Logo
602 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
