Question about LG WM1812C Front Load Washer
Washer displays an le code, we have cleaned the filter and unplugged the washer, still getting the code. what do we do
  • 71 Answers
LE ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy : Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
this is straight out of the repairmans manual on the le code...hope it helps you out!!!!
Posted on Oct 04, 2009
My washing mAchine is broken?
code le = thermal overload protection
let washer stand for 30 minutes then restart
if code persist call for service
page 28 user manual
Sep 27, 2015 | Kenmore Washing Machines
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
I have an LE code on my washer. I tried resetting machine by unplugging. I still get the code. I also tried running the machine without anything in it. It still stops and give LE code. What should I do?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | LG WM1815CS Front Load Washer
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not go through a complete cycle. It flashes F2 and will sit on SUD for ever as well as run on the last 1 minute for an hour. Help
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed. Si la durée de l’opération de vidange est de plus de huit minutes, le système commande la fermeture des électrovannes et l’affichage du code “F/02” clignote. Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement. NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus tard le code “F/02” sera affiché. Possible Causes / Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG WM1812C Front Load Washer Logo
229 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
