Question about HP PSC 2175 All-In-One InkJet Printer
I can't get it to scan. I can't find original install discs so I'm not sure if I have all the features downloaded to my Mac OS X 10.4.11
    Sergeant:
    Novelist:
  • 191 Answers
You can get the drivers free of charge directly from HP here: http://h10025.www1.hp.com/ewfrf/wc/product?product=90809&lc=en&cc=us&dlc=en&dlc=en&lang=en&cc=us
Posted on Oct 04, 2009
Tip
Reset your Apple's Original Admin Password.
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    Choose a language, click the arrow button to continue,
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    Select your Mac OS X hard disk volume.
  3. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
on Feb 10, 2010 | Computers & Internet
HP Photosmart C3180 All-in-One printer, Scanner, Copier will not scan with Mac OS 10.4. The button flashes for a few seconds, then stops and nothing happens. No image appears on my computer screen.
All lot of those printers came with two separate driver's disc. Make sure that you are installing the correct for the mac and not windows. If you are you can go to the hp website and do a search on there website for the driver for mac operating system.
Apr 25, 2011 | HP Photosmart C3180 All-In-One InkJet...
Cannot scan from HP 6500 E709n (No Scan Options). I'm on a Mac OS X 10.6.6. I lost my disc and maunal. And I recently had my Hard drive replaced. So this was lost in the process. Can I get a free...
You can, and it's really easy!
Go to this site and download the software under drivers called "HP Officejet and Photosmart Full Feature Software and Drivers - Mac OS X v 10.6".
Unplug your all in one printer/scanner and install the program. Then plug the printer/scanner back in and it should work fine - you'll have all the options you had previously.
Mar 15, 2011 | Office Equipment & Supplies
How can I find the admin password on my mac. I had a new hard drive put in my pc. I want to change some of the admin settings but I need the password. How can I find it or change it without knowing the...
  5. Click Save.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Feb 10, 2010 | Apple MacBook PC Notebook
I forget username and passowrd in my MAC OS X Version 10.4.11,please findout the solution to restore my username and password.....
Did you lost the administrator password? There is a way to reset it. You will need the install disk in the resetting process. Please make sure you follow the steps accordingly.
From Mac OS knowledgebase:
  2. Choose a language, click the arrow button to continue, then choose Reset Password from the Utilities menu (or from the Installer menu, if using Mac OS X 10.3.9 or earlier). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
    Note
  3. Select your Mac OS X hard disk volume.
  4. Select the user name of your original administrator account.
  5. Enter a new password.
  6. Click Save.
Sep 04, 2009 | Apple Mac OS X 10.4
DOWNLOAD INSTALLATION DISC FOR MULTIPASS C555
Unless you're installing the software on Mac OS9, or Windows 2000 or earlier, the original installation disc isn't going to do you any good. Drivers are available here for Windows XP and earlier and Mac OS9 (there are no drivers available for Mac OS X). Be sure and read all notes (when you click on a driver download link), and get the upgrades for Windows 2000 or Windows XP SP2 if you're installing on either of these systems. Good luck!
Nov 10, 2008 | Canon Office Equipment & Supplies
Hp officejet 6110xi all in one
I did a search of your product's help pages on HP.com but didn't come up with an exact match for your error message relevant to an Apple Mac OS X. Before offering suggestions, let me make sure I understand the problem.
You have a Word document open on your Mac and you want to insert an image into the document that's on the scanner.
I'm actually not clear as to whether you successfully scanned an image in the first place. If you did scan the image, where did you store it to? Have you tried scanning the image and saving it to your computer? If you can do this successfully, try inserting the image into your Word document from the location on your computer.
If you tried to scan an image and got the error message, then there is a communication problem between your Mac and the printer. Since you can print, the cable connection must be good. If the error message is suggesting that you reinstall the drivers, you can find the instructions for how to do this at the following web page at HP.com:
Installing and Uninstalling Printer Software on your Mac
You may or may not have your original software disc that came with the printer. If you don't or if you need an updated print driver, you can download that software from the following web page, assuming you are running Mac OS X:
Mac OS X Printer Software and Driver Downloads
Occasionally, you can solve errors by installing print drivers that are more recent than those you originally installed when you first got your printer. That's the benefit of downloading the latest drivers from HP.
On the off change you are using Mac OS 9, here's the relevant software download page (the version of the Mac operating system matters):
Mac OS 9 Printer Software and Driver Downloads
If all you want to do is to insert an image into a Word document, you shouldn't need Adobe Photoshop or any other expensive software application. You aren't trying to do any fancy editing of the graphic, just insert a pre-existing image into a document.
I hope some of the above suggestions help. Post back your results and good luck.
Oct 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lost installtion disc
Hi there, you can download some installer online for you printer machine, just type this link to your browser:
http://www.lostmydrivers.com/printers-drivers/lexmark/
and please find below details on a bit middle part of the html page, click download. Make sure the your printer wire are plugged and use it as your default printer and have it test. Thanks. Have a nice day.
Regards,
fixyaqueen.
LEXMARK LEXMARK P4350 PRINTER V.1.0.6 MAC OS X 10.2.3 MAC OS X 10.2.4 MAC OS X 10.2.5 MAC OS X 10
Lexmark P4350 printer Driver for Mac OS X 10.2.3 - 1...
Licence: Freeware
OS: Mac OS X 10.2.3, Mac OS X 10.2.4, Mac OS X 10.2.5,
Size: 20 MB 07/13/2007 173 -
download now
Sep 24, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lost installation disc
Licence: Freeware
Regards,
fixyaqueen.
HP PSC 2175 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
