Question about Jenn-Air JS48FXXXDA
I need to replace the Main Control PC-Board of my Jenn-Aire refrigerator. Where can I buy this part?
  • David Jewell May 11, 2010
    Do a search for appliance parts in your favorite search engine to find retailers. You can even buy parts on Ebay. Look in the technical manual for the part number of the board you need.
    President:
  • 1,304 Answers
Appliancepartspro.com
tell them your odrering for MYYELLOWDOG
and be sure to ask for the discount,
you can search for the part there as well by typing in the model number
be sure to ask for the servicemans discount
Posted on Oct 04, 2009
Need new control board-shorted out. Can I replace? How much?
For what type appliance. Most control boards are replaceable except some jenn aire models
Jul 28, 2015 | Amana PTC123B35AJ 12000 BTU ThruWallWindow...
Jenn-Air not cooling. Repairman replaced 'defrost control board.' Still not cooling. Control to set temperature will not move from zero. Any suggestions appreciated.
Generally when a printed circuit board faults it often takes out the other boards too.
You may need to get the main PCboard replaced too
Apr 01, 2011 | Jenn-Air JFC2087HRP Side by Side...
Jenn-Aire Digital Control Failure
i am having the same problem. did you find a solution to this?
Apr 03, 2010 | Jenn-Air Refrigerators
My Jenn-Aire Twin Fresh Climate Control refrigerator is making loud noises, like the water line is running and then stops abrubtly. Our freezer has defrosted and no ice is being made. I think the...
This sounds like a control board issue. I will need your model number so I will be able to pull up your service manual. Here is a likk to where to loook for your model number and more details of contact details. Click here=> Refrigerator Appliance Model Number Locations Thanks, Sea Breeze
Mar 01, 2010 | Refrigerators
Jenn Air Model JBR2256HES fridge with a warm fridge &cold freezer
yes its a common problem its called the jaz board. the only way to tell is ohming out the sensor and heater the by elimination it is the board. i recomend putting any newer appliance on a surge protector.sometimes depending on the board there is instructions to program it with your serial # also make sure your light swiches are being activated when you shut the door. good luck!
ERIC
Feb 09, 2010 | Refrigerators
Jenn Aire frig is 6 years old and compressor is bad. Should I replace it or buy a new one?
check the warranty on the unit, if no warranties are valid anymore i would proabaly replace the unit... most compressor repairs can range from 300-800 dollars after parts and labor so its kind of whuts a cost effective way to go ...
Jan 31, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Jul 07, 2009 | Ovens
Jenn-Aire Refrigerator Shutting Down
sounds as if the control board has gone bad unless you have an extended warranty that you purchased extra this will probably not be covered, but check with jenn-aire to be sure. I dont think I would worry about a 3rd compressor being bad but I would unplug the unit to prevent any further damage to it. good luck peyton
Jan 30, 2009 | Jenn-Air JCD2295KE Side by Side...
Jenn Aire JGS9900BDS
it is probably the control board. Mine did this and they changed the control board.
Oct 26, 2008 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Jenn-Air JS48FXXXDA Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
