Question about PfaFF Creative 7570
I can only sew straight or very little width stuff. The needle hits on something when it moves to the left.
  • 632 Answers
I suppose you already have the needle position in the middle. Try selecting the widest stitch set on the right side, See if it hits anything and if it's the same distance as the left. If it's not then you'd need a service person do a complete alignment, timing and other related service to zero your machine.
Posted on Oct 06, 2009
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
Needle hits something and breaks on my pfaff 2140
check that the selector button is fully down on the straight stitch. It should matter if the needle is straight and you have a zig zag plate on the machine. The other option is that the needle is bent and a new one may fix the problem. They dont need to be out by much but you said you had broken needles so it might even be a timing problem and hitting the bobbin case rather than taking the thread to be picked up by the racer.
Mar 26, 2014 | Sewing Machines
How do I change the position of the needle (right/left) on my Janie 6019 QC sewing machine?
You may only be able to adjust this one or two spaces. When you have the straight stitch selected, try moving you stitch width slide wider. If you needle is in the correct position, you should see it move as you slide the lever.
Sewing Machine Tech
Oct 24, 2013 | Janome 6019QC Mechanical Sewing Machine
Viking 1+ Horizontal movement quit working after needle hit something
it sounds like you knocked the machine out of time & it will have to be taken to a
sewing machine shop to be retimed
Apr 26, 2012 | Sewing Machines
I can't remember how to make the needle position on my 1630 Bernina stay either to the left or right so that I can insert a zipper with my zipper foot. Can you help?
HI Evelyn,
sometimes its just the little things that stop your sewing project; so annoying isnt' it.
According to the manual I've found, this stitch width inner knob is turned to move the needle position. The outter part controls the zig zag width, so just move the inner knob to move the needle.
Hope that makes sense to you. Good luck finishing your project.
Jan 02, 2012 | Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 02, 2011 | Elna Quilter's Dream 6003Q
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did...
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Nov 04, 2009 | Singer 2732 Mechanical Sewing Machine
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
74 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
