Question about Garmin Nuvi 265W GPS Receiver
We have 3 nuvi265w that have no voice. Also one will not pair to any bluetooth device. They had voice in the beginning and now do not. I did the update downloads and that seems to be when we stated having problems. I did put some garage vehiles on.
  • 2,335 Answers
I can help you reset and fix your Garmin Nuvi 265W. If your nuvis are not acting properly after a webupdate, try it again with the newest webupdate software (available below). After backup up your favorites, and performing the webupdate, try the hard reset AFTER the webupdate. This sequence has been known to help.
  1. Back up your Favorites.
  2. Download and then run Garmin WebUpdater to replace its firmware / system software.
  3. Perform a Hard Reset.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Posted on Apr 19, 2010
I cant turn on the bluetooth on my zte sonata phone to listen to my music on my LAX MAX bluetooth speaker.
  1. Before you begin, place the Bluetooth device in pairing mode . Open the Notifications panel and tap Bluetooth . Or, from the home screen, tap > System settings and slide the Bluetooth switch to the On position to turn on Bluetooth . When Bluetooth is on, the icon will appear in the status bar .
  2. Tap Bluetooth .Your phone will automatically search for Bluetooth devices and will show all visible devices in range .
  3. Tap the device you want to pair with .
  4. If necessary, confirm that the Bluetooth passkeys are the same between the two devices and tap Pair . Alternately, enter a Bluetooth passkey and tap Pair .
    Pairing is successfully completed when the other device accepts the connection or the same passkey is entered .
Dec 28, 2014 | Cell Phones
Pair iphone to general motors car
  • Get into your GM vehicle with your Bluetooth compatible cell phone and turn both on. Use the dashboard controls to turn your GM's Bluetooth system to its "Discovery Mode."
  • 2 Go to the Bluetooth application on your phone and turn the Bluetooth mode on to its "Discovery Mode." Now your phone will begin searching for other Bluetooth devices within its range. When it locates your GM's Bluetooth, your phone's screen will show the name of your vehicle and ask if you'd like to continue syncing the two Bluetooth devices. Select "Yes."
  • 3 Enter the numeric code that appears on your GM control panel screen into your phone and continue the pairing process. While pairing, your phone will share your contact information with your GM to enable the Caller ID on the dash screen to work.
  • 4 Confirm successful pairing by making a phone call. Make calls using your GM's voice activation, which is done by pushing the "Phone" button on your steering wheel. You can also dial from your phone's keypad and the sound will transfer to your GM's speakers.
  • Jan 23, 2014 | Apple iPhone 5
    Sharper image freedom Bluetooth model number ESI-P400 how to put in pairing mode.
    To pair your device with The Sharper Image Freedom:
    1. Make sure your device has Bluetooth capability.
    2. Slide the POWER switch to turn on the Freedom, indicator will begin to flash.
    3. Follow the instructions of your device to pair the unit.
    4. Pair your device with the unit by selecting FREEDOM from your Bluetooth listings on your device or selecting YES. If prompted, enter "0000" as the passcode.
    5. Press play on your device and use controls on the unit to adjust desired volume.
    Note: Once you have successfully paired your device, you typically will not need to repeat the above steps. Please ensure the Line-In cable is unplugged, the unit source is set to Bluetooth and your device has Bluetooth enabled.
    Note: The effective Bluetooth range of the Freedom is approximately 30 feet.
    Nov 19, 2013 | Radio Communications
    Sharper image freedom Bluetooth speaker model ESI-P400 discovery mode button sequence
    Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
    Instructions
    Pair Your Blackberry with a Bluetooth Headset
    Turn on Bluetooth headset and Blackberry hand-held.
    Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
    Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
    Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
    Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
    Use your Bluetooth Headset with your Blackberry
    Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
    Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
    Press the on/off button on your headset to end a call or use the end button on the handheld.
    Tips & Warnings
    Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
    Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
    Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
    Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
    Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
    Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
    Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
    I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
    Hi,Instructions on how to pair blue tooth device with black berry.
    Tips & Warnings
    Have a nice day .
    Feb 16, 2011 | Jabra BT125 Headset
    My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
    Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
    You can use the below steps to know how to pair properly:
    Instructions
    Tips & Warnings
    Hope it helped.
    Thanks for usingf ixya..
    Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
    Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
    1. Turn on Bluetooth headset and Blackberry hand-held.
    2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
    3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
    4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
    5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
    1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
    3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
    Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
    Connection
    Begin with your headset turned off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and make the application proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise, just press the answer/end button, and the link should be done again. In this case, it might be prudent to place the headset in your ear and check if the voice channel has been actevated (you can actually hear it). If so, either press the answer/end button again, or turn your phone off (i.e. just put it in stand-by), and make sure the voice channel has been cut off. The bluetooth connection will still be in stand-by.
    Hope you are able to sort your problems out.
    Cheers! Carlos
    May 28, 2010 | Jabra BT350 Bluetooth Headset Headset
    Discovery mode
    Cheers! Carlos
    May 12, 2010 | Jabra BT350 Bluetooth Headset Headset
    Garmin Nuvi 265W GPS Receiver Logo
    130 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
