Question about Kodak EasyShare One Digital Camera
My kodak easy share all of a sudden quit reading my kodak high speed card why??
My kodak easy share was not support another sdbcards
SD Cards are of different types size and capacities.
Avoid higher capacities and faster speed for older devices.
You will need to match for a compatible type.
How to Buy an SD Card Speed Classes Sizes and Capacities Explained
Jul 16, 2016 | Kodak Cameras
Kodak easyshare troubleshooting
When you have removed all the pictures on the card next time, format the card. this will clear out all the pesky little bits that haven't been erased yet. This should speed up the card again.
Nov 29, 2013 | Cameras
PNY optima sdhchd 8gb won't read in my Kodak easy
What model Kodak EasyShare camera? Some of them only work with SD cards, not with SDHC cards. The same applies to kiosks. Make sure the slot is marked "SDHC' and not simply "SD".
Feb 05, 2012 | SanDisk Cameras
How do we move the photos to the memory card in the camera?
Get out your manual and read the chapter about file transfers. It should be fairly simple to move the files from internal memory to external memory.
Aug 06, 2009 | Kodak EasyShare Z1275 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
Camera does not read memory card
Have you tried another card, to see if the card is at fault?
Freddy
May 23, 2009 | Kodak EasyShare Z885 Digital Camera
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 03, 2009 | Kodak EasyShare C330 Digital Camera
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare One Digital Camera Logo
29 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
