Question about Panasonic KX-TG1033S Cordless Phone
RCA H5400 Cordless phone
Lots and lots of static..Have changed plugs and changed plugs on base and changed channels etc. No difference
  • 1 more comment
  • Anonymous Jan 10, 2008
    have charity cordless phone for hearing inpaired (has static ) have replaced cord /battery/ moved to various phone jack still have static
  • sellers437 Nov 21, 2008
    I have the same problem. I can hardly hear for the static. How do i fix this?
  • fibeger May 11, 2010
    Our wall phone works fine, but suddenly after 9 months of working perfectly, our 3 handset Panasonic phones are full of static whether on incoming or outgoing calls
Lots of static when I turn it on. Changing the channels does not work. Having no onother appliance plugged into the outlet doesn't work. Moving it away from other appliances doesn't work. What should I do?
Posted on Jun 26, 2008
The broadcast channel can't be changed according to the units instructions some other electronic device is causing the interference you may have to move the base unit. A PDF file of instructions are here
Jan 26, 2015 | Panasonic KX-TG1033S Cordless Phone
Vtech cordless static
The control is usually a sliding switch in the base station, not on the handset. Open the battery holder and look in there,
Dec 20, 2013 | Vtech DECT 6.0 Digital Cordless Phone
There is a loud buz on the phone line
is there a channel selection button/. if so try selecting different channel as lots of electrical equipment can interfere with walkabout phones as can hearing aids. have u asked neighbors if they are having same problem? might be a fault on line? u can check to see if there is a fault on the line by going to bt faultfinder and typing in your phone number and they check it for u for free. hope some of this helps?
Feb 24, 2013 | Panasonic KX-TG6524 Cordless Phone
How to get rid of static in phone
read through the instrucyion manual, all cordless phones can transmit to the base on lots of different channels, you may need to reset the channel nuber to a better setting for the base.
Dec 02, 2009 | Panasonic Lands Phones
I have static thru the handsets... i see in the
Move it away from other electronics, TV's microwave ovens, etc. Try it in a different part of the house to see if the static is location sensitive. It must be getting interference from someplace. The manual should describe a procedure for changing channels although that may not solve the problem unless the "static" is an interfering RF signal. If this is a remote handset problem, it may be too far from the base or the signal is obstructed by something. 5.8GHz does not have the range of the lower frequency phones.
Nov 14, 2009 | Panasonic KX-TG6071M Cordless Phone
Uniden ANA9710 Phone has problem charging when set in base, have to take battery out and charge that way. sounds like it's breaking up when speaking...lots of static type of noise. 2nd...
press and hold CID button for 5 seconds to access the phone's menu.
Then change ringer type and volume.
For the phone breaking up, try different channels of that phone to receive better frequency. The phone with the weird battery may have faulty or bad battery or charger contacts that need to be cleaned with rubbing alcohol and need to be resoldered.
Aug 04, 2009 | Uniden Cordless Phone
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
When I have a static problem with a phone or radio it usually happens when I have them plugged into a extension cord. Or they are too close to one another. You may try an ext.cord. just having the phone plugged in or find out why you have so many magnetic fields in your house and if moving the phone around to different outlets help.If not I suggest you call Radio Shack. You can not beat their customer service.
Jan 24, 2008 | GE 25952 Cordless Phone
The cordless phones have a button to change the channels that are within the radio freq. range. I would change the channels until you get a clear/static free call.
May 20, 2007 | Northwestern Bell 35807 Cordless Phone
Cordless disconnects wireless network
Unfortunately, you won't be able to get them to play nice together. Your phone is a 2.4GHz phone, which is the same frequency that WiFi runs on. This will be the case with any 2.4GHz phone you use, regardless of brand. Your only real options are to replace the phone with either an older technology 900MHz phone, or a newer technology 5.8GHz phone. Either solution will work.
Mar 22, 2007 | Sony SPP-S2730 Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
752 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
