Question about Gateway Profile 5.5 Motherboard
Problems with Gateway Profile 5.5 Motherboard the fans don't work
  • 61 Answers
Well it not rigt way but you can plug that in another plug named chesic\system fan
Posted on Oct 04, 2009
Profile 6 gateway
The M/B is probably faulty. There are no fuses on the board.
Jan 24, 2013 | Gateway Computers & Internet
At start up the message says cooling fan not working properly computer is halted....changed both fan and blower, and still get same message
Did you remove the CPU heatsink and refit it using thermal paste, then refit the power to the header on the motherboard. This is usually the fan it refers to
Aug 31, 2010 | Gateway Profile 5.5 PC Desktop
Power button blinking red on gateway profile 4...monitor appears to be on, fan is operating, can hear drive starting but computer will not boot up. Checked power to hard drive and ribbon cables, memory,...
1.Check your power supply by using an Analog Volt Meter, you should check if the power supplied by your power supply is stable,
2.Check your ram if it is faulty. try to clean the lids of the ram using an eraser. If still your computer doesnt work, you should find a spare RAM and test if your RAM is working properly.
3.If you dont have any problems with your RAM, you should try unplugging external PCI cards, AGP Cards, on your motherboard and use the internal devices instead, like built in VGA, sound card, Network Interface Card,just to check if there are no faulty devices which stopped your computer from starting.
Hope this will helped you out mate :)
Jan 02, 2010 | Gateway Profile 4 XLb PC Desktop
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
Gateway Profile 4 with two hard drive failures
How do you know 2 hard drives have failed, have the hard drives been fin in another computer.
most likely the OS is corrupt on the disks caused my another hardware issue, most likey Motherboard IDE/sata controller.
Sep 06, 2009 | Gateway Profile 4 All In One (MPN...
I have a Gateway Profile 5.5 all-in-one PC. A few
Personally I'd try applying some more thermal paste to the top of the processor.
Jul 30, 2009 | Gateway Computers & Internet
Gateway Profile 3se cooling fans don't start every time.
The Internal Fan On the cpu is always on correct? If so the external fans come on when the tower case has a temp higher than 85F. This is perfectly normal
Apr 03, 2009 | Gateway Profile 3 PC Desktop
I have a gateway profile 3 the cpu fan wont come on it gives warning fan absent or broken and wont to go no farther.
First make sure that the CPU fan is properly connected to the motherboard. There is a connector on the motherboard that is usually labeled CPU_FAN.
If the fan is properly connected, but isn't working, a replacement can be purchased for a reasonable price. Check with Gateway or your local computer supply shop and they will be able to help you find the right fan assembly for your CPU.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Gateway Profile 3 PC Desktop
Installing motherboard in gateway profile 4
you need to replace the motherboard if the pc is auto shutting off, maybe even the processor!
May 19, 2008 | Computers & Internet
LG LM190E05 (SL)(01)
Gateway has multiple part numbers for the LCD inverter board. Part numbers V01216400103, V01216400104, and V01216400105 are for the Profile 5 and 5.5 series with a 15" monitor. Part number V01316500104 and maybe others are installed in Profile 5 and 5.5 with 17" and 19" monitors. Also the LG part number for the 19" monitor provided in Gateway literature is LM190E02-A4. There is no mention of the LM190E05 SL in the product specs I have seen. Gateway does make special purpose runs and does change components without much much notice though. The definitive source of exact information is Gateway Tech Support. It may cost you a couple of bucks to get answers, but the value added to your system with a 19" vs. 15" screen to say nothing of the viewing comfort should far outweigh the cost of accurate information. Good luck with your upgrade. Please keep me posted on whatever you try be it successful or not. I too have a Profile 5.5 with 15" and have been considering the larger screen upgrade. BillyB.
Oct 07, 2006 | Acer AL1916S (Silver, Black) (Black,...
Gateway Profile 5.5  Motherboard Logo
105 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
