Question about Pentax Optio 60 Digital Camera
Hi..Screen blank in capture mode
Hi..My screen will not show what I am going to photograph but if I take a picture it shows the picture and then goes blank again.Also can t bring up any menu etc in capture mode
  • Anonymous Mar 24, 2014
    camera shows the black picture in only photo menu
Camera problem---- screen showing blank
loose LCD screen connector
it might be a defective CCD which is a FREE warranty repair by Sony
U CAN GET IT REPAIR FRM ANY SHOP AT A COST OF BOUT 4000
RAHUL
Feb 22, 2009 | Sony Ericsson S500i Phone
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Acer Aspire 5100 new screen and still goes blank.
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Jan 25, 2009 | Acer Aspire 5100 Notebook
Camara not working
try reset ti factory setings. if not, maybe the camera flex needs tobe replace or the camera itself.
Sep 06, 2008 | Nokia N73 Cellular Phone
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
QV-R41 Problem
Try hitting the display button on the camera.
Nov 25, 2007 | Casio QV-R40 Digital Camera
Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Sep 14, 2007 | Canon PowerShot S1 IS Digital Camera
Erasure prevention
Sounds like a CCD sensor problem ( no image in capture mode but ok in playback ). Replace CCD block and will work fine.
Sep 06, 2007 | Panasonic NV-DS65 Mini DV Digital...
My screen is blank on all modes except playback and setup
If you can playback captured images ok but in capture mode your screen goes blank and taken shots are black then the CCD sensor in your camera is faulty and has to be replaced. Nikon agent -if you can find one- will do this for you but it may be uneconomical repair on this entry level model.
Apr 30, 2007 | Nikon COOLPIX P4 Digital Camera
Pentax Optio 60 Digital Camera Logo
104 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
