Question about Acer NSK8458AN Keyboard
Delay when using keyboard - Acer NSK8458AN Keyboard
    Scholar:
  • 115 Answers
Is this a wireless keyboard? if it is that means your sensor that is connected to your computer is not close enough to recieve the signal, if this is not the case your settings for your keyboard could need changing. To do this go Start - Control Panel - Printers and Other Hardware - Keyboard - (first tab will say speed) the marker should be at the third line. This is how fast the computer repeats the character to you when you type. If you want it faster you can set it all the way. Hope this helps. Cheers.
Posted on Oct 04, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Keyboard mistyping issues
    1. Change to United States-International keyboard layout.
    Manually change to United States-International keyboard layout
    2. Use the Microsoft Fix it 50558
    3. Confirm if the Keyboard is wired or Wireless
    Information:
    Ensure that batteries are new for the wireless keyboards as drained batteries can
    cause delay.
    Slow computer can also cause the issue. Check if computer is slow and perform necessary troubleshooting steps related to performance after following below provided troubleshooting steps
    Steps:
    Clear Turn on Filter Keys, or adjust the settings to a quicker rate for Windows Vista and Windows 7
    Clear the Use Filter keys check box, and then click OK for XP
    adjust your keyboard's repeat delay and rate settings
    Drag the Repeat delay: slider to Short
    Drag the Repeat rate: slider to Fast
    Click OK.
    Close all windows
    Is issue persists, Reinstall the Drivers
    Follow below steps :
    http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
    Mar 22, 2014 | Dell Inspiron 1525 Laptop
    When typing I can see letters with 3sec delay on the screen
    This is not keyboard issue
    if you are using windows xp , do the following
    goto RUN
    type %TEMP% enter
    and delete all files, then restart computer
    then you can check
    thank you
    Jun 30, 2011 | Compaq Keyboard
    Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
    your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
    Jan 08, 2011 | Intel Motherboard
    The keyboard is super sensitive making it impossible to type without many many errors. Is there any way to harden the keyboard?
    In your control panel, you should be able to access keyboard settings and adjust the repeat delay rate for keystrokes as well as the delay before the repeat starts.
    Apr 17, 2010 | Toshiba Satellite P105-S6104 Notebook
    How do I get my Gear Head Wireless Keyboard shut down.
    It has no off function. It uses little to no power when in stand-by (Not in use). It even has an auto off function after a delay. Just replace the batteries when they run out.
    Apr 12, 2010 | Gear Head Wireless Bluetooth V 2.0 Desktop...
    Delay problem
    Not sure how you are defining delay. Are you recording to the hard drive using the sound card as inputs? Are you listening to the speakers while you are recording or are you playing a recording back and there is delay or echo in that? PLease let me know
    Sep 18, 2009 | Computers & Internet
    Delayed response for keys
    go into your control panel (classic view if you are using vista)... click on the keyboard icon... you can change the delay rate there
    Robert
    Please take a moment to rate this solution... thanks
    May 22, 2009 | Dell Inspiron 1501 Notebook
    Delay on typing words
    Plz reinstall your's keyboard driver.
    Apr 01, 2008 | Labtec 967307-0403 Keyboard
    Delay on keyboard when using with cubase and reason
    this is because of the lantency of your sound card and your driver settings.
    with 2 seconds,
    that sounds like you're using a MME driver for your card.
    try to change the driver to ASIO (if possible),
    if not, change it to directX
    you can do that that way:
    - Open up Devices > Device Setup > VST Multitrack
    - Drop-down the ASIO Driver settings on the right side of the screen
    Nov 06, 2007 | Steinberg Cubase SX3
    Acer NSK8458AN Keyboard Logo
    89 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
