Question about Canon PIXMA MP780 All-In-One InkJet Printer
Laambsee asks: My Canon PIXMA MP780 keeps
Laambsee asks: My Canon PIXMA MP780 keeps bringing up a message which says (check printer) then press OK. Can you tell me please what I have to check
  • laambsee Oct 04, 2009
    Thank you michael_grey. I have done that & now I am waiting for the hour. The led read out keeps flashing Check printer (then press OK). As I said before I am not sure what I am supposed to check. BUT as you suggested, I have removed the cartriges & the print head & removed the machine from all power sources. Will see!!! Thank you. Will let you know.
  • Michael Grey
    Michael Grey May 11, 2010
    Remove all cartridges and print head.Power off machine for an hour(unplug from wall) Re-install everything and see if you still have the meaasge. If so count number of flashes.
old marine
  • 1983 Answers
SOURCE: Lost installation disk for canon pixma mp780
Go to this link. Wait a few seconds for all the files to load. Select your OS in the box, then wait a few more seconds, and you will see the drivers displayed.
You will need to download and install both the driver and the MP Navigator (under the Software heading). Click on the link and follow the instructions to install.
Posted on May 20, 2008
  • 181 Answers
SOURCE: canon pixma mp110 saying ''please load paper and press ok''
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Posted on Nov 17, 2008
Joed911
  • 4338 Answers
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
57 varieties
  • 1653 Answers
SOURCE: canon printer pixma mp780 makes repeated clicking
This is the Automatic Sheet Feeder [ASF] Cam Sensor Error
Movement may cause the plastic guide to move away from the chassis which causes the gears not to rotate properly causing a grinding noise and 5 alternating blinks (SFP) or ##356 (MFP) - ASF Cam Sensor Error.
Remedy: Adjust the Screws & Main Case Unit
Step 1: Remove the Left & Right Covers and the Main Case Unit (main cover).
Step 2: Remove the 4 mounting screws from the Chassis.
Step 3: Remove the Main Unit from the Bottom Case.
Step 4: Turn the Main Unit over (upside down) and place on work surface.
Step 5: Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis. The size of the gap varies. Even if the gap is not visible, complete the steps below.
Step 6: Disconnect the appropriate cables and remove the Logic Board from the Chassis.
Step 7: Loosen but DO NOT remove the 4 mounting screws which can be located behind the logic board on the Chassis.
Step 8: Reseat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic guide should sit slightly inside the mounting screw hole. When seated correctly, the gap will no longer be present.
Step 9: Tighten the 4 mounting screws without causing the plastic guide to shift.
Step 10: Reassemble the printer and retest.
Posted on Oct 01, 2009
SOURCE: Wireless printing on Canon Pixma MP780 printer.
Excuse me I was wondering how i can tell if my printer has wireless capabilities? It is a: Cannon pixma mp780
Posted on Sep 24, 2010
Hi my printer PIXMA MP780 all in one is not working when switched on it gives me the erra message ##357. everything is on but its not working. Please help
357 ASF paper feed (AP) position error
Cause: An error occurs at the AP positioning in the ASF (Auto Sheet Feeder) unit.
Solution: (1) To reboot, press [OK] button or turn off and then on the power.
(2) Replace the SHEET FEED ***'Y.
(3) Replace the SPCNT board.
Nov 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon pixma mp780 all in one printer. It keeps saying add paper but the paper tray is full.
Check the feed switch, you can put paper in the bottom tray or the top feeder and you press the feed switch to change from one to the other, when the rollers are dirty and paper doesn't pick up you also get that error.
Jan 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Message: Check Printer Press OK (No Code)
Could be many things, you have to enter service mode to get the actual error, could be waste ink full, purge or feeder error, printhead failure, I would bet on waste ink full, a shop repair.
I have a Canon Pixma MP780, keep getting "clear ADF" messages. changed the settings to off. Also, scanner is giving me some error messages #2, #178
Try Canon support. Type your query. Click "Search"
Example: Type "clear ADF" (You may have paper or some obstruction in the Auto Document Feeder).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Nov 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
You get that message when the printhead goes bad. It's not the ink cartridges. You need a new printhead
# QY6-0049-000 around $60.00
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error message 6A00
Hi
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer pixma 780
Press MENU SCAN COPY than SCAN
Cycle throught options until #7 PRINTER
Pres OK
Cycle throught options untill #5 INK ABS CAP
Press OK
Display SUCTION
Enter 0
Press OK
Turn Printer off
Pause
Turn Printer back on
Feb 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge Jammed
Try removing the print cartridge and then insert it again this should clear the problem.
Feb 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have pixma MP780, paper went in crooked, but appears all came
check in the back of the printer, open the little door to see if there's still paper in there.
Nov 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Software for canon pixma mp780
Not knowing where you are from, I can only give the following help.
Do a Google search using the following text:
pixma mp780 +driver
Note the "+driver" (no space between the "+" and the word "driver").
This will bring up a lot of sites where you can dowload the drivers.
Apr 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
