Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Water goes in but never fills, water just keeps running
  • 71 Answers
Well it could be a couple of things.....there is a clear tube that runs from the outer tub up to the water level switch.(small, medium,large,etc...) make sure the tube is hooked up on both sides....if it is take it off the switch and blow through it to make sure it is not plugged with fabric softner. If you have done both of those things and it still does it then you need to replace the water level switch. Part number for switch is PS975847 and it runs right around $50.
Posted on Oct 04, 2009
Why when we start the wash the water goes in and drains right out so it just keeps doing that
check your drain hose going to the drain pipe in the wall. if the drain hose is lower than the highest water level on the unit, it will cause a siphoning issue. water will run into and the never fill enough to start into cycle. If unit is filling and the drain pump is on at the same time it is filling, then it is a bad control board.
Feb 12, 2015 | Amana Washing Machines
06 impala bleed air out of cooling system
Put heater on high heat to circulate water in those hoses and heater core. Then start the car after removing the radiator cap and filling with coolant to the top. When the radiator opens you will see the liquid level go down- add more coolant and keep adding till it stays full. Meanwhile fill the overflow to recommended level. When radiator level goes down no more, put radiator cap back on and let engine and coolant cool. If any more water is needed the vacuum created by the shrinking water will draw it in from the overflow.
Jan 11, 2012 | 2006 Chevrolet Impala
I bought a top load washing machine model number WF T7239 UL on 05Nov2010. Water sensor does not seem to work. Water just keeps filling up the drum and starts overflowing once filled.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Nov 06, 2010 | LG Washing Machines
The water filling the tank does not turn off, it keeps running
It sounds like the fill valve is not operating correctly. Remove the fill valve which it the tall item inside the tank where the water runs through and replace it with a universal replacement part from your local hard ware store. Take the valve to the store so that you can get the proper replacement piece.
Jul 11, 2010 | Toto Promenade, 1.6 GPF, Elongated...
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore top load washer keeps filling, watere
the fill valve is bad or there is a hole in the tubing that attaches to it, this tube goes from the pressure switch to a bulb on the side of the tub only air pressure goes through this tube one small mouse bite and it is damaged
Jul 06, 2009 | Kenmore Washing Machines
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
