Question about BenQ PB6200 Multimedia Projector
Flickering dots on Benq PB6200 projector.
I have a Benq PB6200. Lamp is approaching 3000 hours. When first turned on, I get white dots, forming some 'sinusoidal' patterns or flickers around 'brighter' images, irregardless of input source. The blue startup screen shows no anomalies, only during playback. This goes away after 1-2 hours and all looks okay. I want to replace lamp, but not if this is a major issue. Any ideas?
  • Anonymous Mar 15, 2014
    pb6200 benq "blown fuse"
    New Friend:
White dots on display so how cane remove white dots from the display?
Posted on Sep 18, 2013
  • 2,237 Answers
It's not the lamp. if you've replaced the cords and still have the problem, reset the settings to factory default to make sure the resolution matches. if still not ok, there may be an issue with the main board.
Posted on Nov 12, 2009
The fans are on all the time, no light though, the buttons on the unit do light up. Would this be the lamp?
The fans are on all the time, no light though, the buttons on the unit do light up. Would this be the lamp? No lights on POWER, TEMP and LAMB
Sep 12, 2010 | BenQ PB6200 Multimedia Projector
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
My pb6200 benq projector's colour is wrong. Missing green. Has a lot of blue & red. How do I fix this please? Have since replaced the lamp - does the same with both old & new lamp. Also has a...
Your correct about missing your primary color. this could be either your cable or the connection at the projector could have a bent pin on the port. not sure what your trying to display computer?
Jun 01, 2010 | BenQ PB6200 Multimedia Projector
BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Nov 05, 2008 | BenQ PB6200 Multimedia Projector
Mainboard of PB6200
Hi, I'm looking for a mainboard too. Just last week one of the PLL clock multipliers wacked-out and overclocked one of the DLP ICs. (confirmed by O-scope and service manual). Guess they timed the warranty just right before the units start to die.
Jun 18, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BENQ FLAHING
Hi cvijr
This can only one of two things - the lamp or the Ballast ( lamp's powersupply )
Normally the PB6100/6200 lamp's has got markings on the lamp itself when this flickering occurs.
Take out the lamp by unscrewing the lamp door at the bottom. Then look for any vein like looking marks in either black or white. Or even a bubble at the bottom end of the lamp's shaft.
If you can spot anything out of order , then the lamp will need replacement.
If not , then you'll know for sure that it is the Ballast that is in need of either repair or replacement.
Part Numbers :
Ballast :5D.J8612.011
Lamp : 60.J8618.CG1
Hope this is of help and thanks for using Fixya !
May 05, 2008 | BenQ PB6100 Multimedia Projector
BenQ PB6100 extremely dim screen/projection
Hi skeeterJ
This is most probably your lamp , I have had loads of PB6100 's that has even had less hours on the lamp than yours and needed replacement.
Keep in mind that the 2000-3000 hours they talk about on a lamp is just a rough factory estimate. The time you get on a lamp is determined by how you use the Projector - because at the end of the day the lamp is just like a globe in your home - it doesn't like being swithed on and off for short periods. This is a mistake most Projector owners make - by thinking they are saving the bulb's lifetime and switching it off for short periods.
You can take my word on this as I am a Authorised BenQ Service Technician.
I've had clients who got 10 000 hours on one bulb just because they left the unit running for longer periods.
Lamp Part No : 60.J8618.CG1
Easiest way to make 100% sure before investing in a new lamp is to take out the lamp by opening the lamp door at the bottom.
Check for any vein like looking marks in either white or black or a bubble on the shaft.
If you have any further troubles or questions , feel free to post another posting and I'll answer it for you ASAP.
Thanks for using Fixya and good luck !
Apr 24, 2008 | BenQ PB6100 Multimedia Projector
Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Apr 07, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ PB6200 Multimedia Projector Logo
658 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
