Question about Westinghouse L1975NW Monitor
I have a Westinghouse L2046NV lcd monitor. It was working earlier. I moved my computer, unhooking and rehooking the connections. Now when I boot the pc I do get the windows 98 curtain and it shows up clear, but when the desktop is just about to show the screen goes "near" blank. I say near because I can faintly see the image of the desktop. I tried going from the digital connector to the analog connector. If I turn the monitor off and on the desktop will show clear for a second and then dims again.
  • 1,684 Answers
You have a monitor with a very common problem, a blown power supply. The heat that builds up in the monitor case causes parts called capacitors to overheat and blow out. When you turn on the monitor they try to hold a charge and show a picture but loose the charge fast and the picture goes dark. If you can solder then you should be able to do the repair yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm and look at the pictures of what the blown capacitors look like. Now open the bad of your monitor and replace any that look like the pictures. The values that you need to purchase will be marked on the sides of the blown ones but will be values like 220uf, 470uf, 1000uf and then a voltage rating. Be sure to get high temp (105c) replacements or you will have to do the repair again in a month or two. The parts at Radio Shack will not do there are several places on the internet to order them from or we can supply you with them. When you install the new ones just insert the caps with the polarity stripe going the same direction as the old ones come out. If you have any questions just let me know. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 04, 2009
I have a Westinghouse L2046NV Monitor and it does not come on. The monitor has gotten worse over time. I have removed the power board and found the six capacitors to the right are all bulging and 3 of them...
You may want to get the capacitor kit, but you need to get the board number used in your monitor version.
Eample of the kit:
http://cgi.ebay.com/Westinghouse-L2046NV-REPAIR-KIT-LCD-Monitor-DAC-19M005-/320608826408
I will not use RadioShack caps, since they are not low ESR type which is required for switching power supply, they will not last if you use generic electrolytic caps.
You should remove one cap at a time so you can see what the value is for each cap.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 18, 2011 | Westinghouse L2046NV Monitor
How do you open a Westinghouse L2046NV monitor? I tried removed the two screws on the back and it still won't come apart? Please help!
Stand removed? Try lifting up the front bezel and then use thin screw driver to separate the front bezel from the back, but watch out for any attached to the front bezel. see exaples here:
http://s807.photobucket.com/albums/yy352/budm/Dell%202408WFP%20Rev%20A02/
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 30, 2010 | Westinghouse L2046NV Monitor
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
I need a parts for a Westinghouse LCD Monitor. Model number is L2046NV
What parts do you need?
You can get service, parts and DIY info from LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 21, 2009 | Westinghouse L2046NV Monitor
Black screen
Hopefully, she registered it with Westinghouse. Call their tech support.
maybe a transaction printout from her bank account will suffice.
Mar 03, 2009 | Westinghouse 25.5" Widescreen Flat Panel...
Sounds
If you have the L2046NV you won't get sound because if has no speakers.
Dec 09, 2007 | Westinghouse L2046NV Monitor
Westinghouse L1975NW Monitor Logo
143 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
