Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Bose SoundDock burned out two of my iPods - a Nano and a classic.
After docking my iPod classic last week, the Bose soundDock wouldn't play it and then my iPod completely shut down, I could not reset it...dead. About two days later, my daughter put her Nano on the same Bose Dock and her Nano completely burned out. Can't reset. Dead. Gone. Flat lined. Any help for my sound dock???
    Scholar:
  • 51 Answers
Hi, can be a problem if you plug a later Apple device into a dock that doesn't support USB charging. There is a much higher voltage on the dock connector on the older docks. The power is presented on different pins but they are very close together and any damage to the connector and even a previous liquid spill can cause the higher voltage to get where it shouldn't. The most inexpensive way to solve this is to fit a USB charge upgrade. This removes the high voltage from the dock connector. To check if your dock needs it - go to the invebo.com site and enter your serial number - it will tell you which version of internal hardware you have and if it supports USB charging for the later Apple devices.
Posted on Apr 27, 2012
    Problem Solver:
  • 11 Answers
Um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Posted on Oct 05, 2009
Ipod classic 80GB makes a horrible popping noise with sounddock II
Sounds like there might be a loose connection between your iPod and the dock. Firstly make sure there is no dust or grit inside the female 30 pin of the iPod. Also make sure that there is no grit or dust around the male end on the dock. If there is grit or dust (or even if there isn't, some compressed air (you can buy this in a can) will help to clean out the connection. Also make sure that when you dock the iPod, it is seated on the dock properly. You should be able to see if it isn't seating properly. If this doesn't fix it and you are near an apple store, I would recommend taking the problem to them where they will be able to make sure that the iPod isn't causing the problem.
Nov 30, 2013 | Bose SoundDock Digital Music System for...
I just bought a new Nano and tried to plug it into my Bose SoundDock stereo system for iPods to listen to music. I received an error message that said: "Charging is not supported with this accessory." The...
Hi. Try to reset the Nano by pressing the middle button and menu at the same time. If same thing happened, i suggest you need to have your sounddock system checked with the manufacturer.
Sep 13, 2010 | Bose SoundDock digital music system...
Ipod charges on bose dock but won't play ipod firmware 3.1.2 recently updated
i have bought a ipod nano and i want it to work in my car stereo it charges but does not play it does play my sons ipod touch so the cable is ok
Feb 07, 2010 | Bose SoundDock digital music system...
Bose Portable sound dock remote not working with iPod Classic
I have the same problem with mine. Called Bose Belgium and waiting for answer but it seems there's nothing to do.
Wait and see
Sep 21, 2009 | Bose SoundDock Digital Music System for...
Bose Docking Station incompatibility with IPOD Touch
You need to reset your ipod. You can go online to find out how to do this. I had to do it with mine and then it worked perfectly.
Aug 08, 2009 | Bose SoundDock digital music system...
New ipod nano not compatable with bose docking
This is true. The new iPod nano is not compatible with the original SoundDock. This only means that it won't charge the iPod's power. Audio should be okay. This is an Apple issue. They changed the way almost all of their iPods charge (except the iPod classic). Bose can upgrade the SoundDock for their normal repair fee of $99. This would also you a new 1 year warranty.
Jun 23, 2009 | Bose SoundDock digital music system...
Ipod classic 80 gb won't charge in bose docking station.
ipod classic will be charge by running itunes programs... now it you dont use itunes, you cannot charge it,...
Jun 19, 2009 | Bose SoundDock digital music system...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Gen 3 nano and bose docking station
Have you tried another iPod on it?? I suspect that if you do, that one won't work either. If it's a Bose SoundDock then they are well known for having problems with the iPod connector getting loose. Try with another iPod. If results are the same, take your SoundDock back. Bose should exchange it straight away.
Aug 06, 2008 | Apple iPod nano 3rd Generation
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
980 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
