Question about Hitachi 42HDT55 42 in. Plasma Television
Hitachi Plasma TV will not turn on.
When I returned home the other day, my digital clocks were all flashing after an appearant power failure. Since then, my Hitachi 42HDT55 will not turn on. The AVC box seems to be OK but I get nothing from the screen unit. I have cycled the power button and checked the connections and everything is in order. Is there a fuse or circuit breaker that may have been tripped when the power went off or when it came back on?
5 Suggested Answers
SOURCE: Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Posted on Aug 13, 2008
SOURCE: ESA 42" plasma tv not turning on
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Posted on Nov 13, 2008
SOURCE: Have aquired a Hitachi 32pd3000e plasma screen but have no media box
Are you still interested in the media box?
Posted on Apr 12, 2009
sethdileswar
  • 253 Answers
SOURCE: Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Posted on Apr 06, 2010
Hello, My Hitachi 42" plasma is about 5 years
A description of the fault may help with an answer.
Sep 18, 2017 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Jan 04, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Hello, I have a p50h401a and the red standby light is flashing. i can power the tv up and it works for about three seconds and then it shuts down, back to the flashing red light. I was wondering if this is...
A lot of modern day tv;s have power supply failures due to capacitors drying out , you can sometime tell which ones are faulty if they swell up or deform. if so they need replaced. Not a hard job for some one who is experienced,
pete
Nov 06, 2010 | Hitachi P50H401 50 in. Plasma HDTV
When TV is off and there is a power outage the TV
This TV has a Power Standby feature (pg. 40 of your manual) which allows you to more quickly turn ON the TV. When power is lost and then restored, your TV will display the HP logo screen while it boots the digital circuits. After it is finished, (unless it was previously turned on) it should appear to be OFF. This is normal operation. If you like, you can change this setting to LOW POWER. At this setting, each time you turn on the TV, you will see the HP Logo screen and picture/sound will appear after 20 seconds. Again, take a look at pg. 40 of your owners manual for more information.
Mar 15, 2010 | HP PL4260N 42 in. Plasma HDTV
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Dec 30, 2007 | Hyundai ImageQuest HP4240 42 in. Plasma...
Tv wont turn on
I paid to have one of the experts on this page help me with my Hitachi 55 in, and all they would recommend was to replace the Convergence Amplifiers. I read elsewhere, that this TV has a habitual problem with fuse E994 and a capacitor c707. I just replaced both for a little more than $5.00, and the TV came back to life!!!! I'll try to find the web page that I referenced for the repair, and let you know.
Dec 23, 2007 | Hitachi 55UX58B 55" Rear Projection...
Screen does not switch on, mode light flashes orange
Need to remove the Input module circuit box from the bottom of the center and wait for few minutes before putting it back.
This will reset the system from this persistant power off problem.
Best way to prevent it from happening again is to manually switch of the power switch before doing any powering off and on. Most commonly happens during a power failure and power coming back on with the switch in the on position.
Oct 02, 2007 | Hitachi 32PD3000 32 in. Plasma Television
Hitachi 42HDT55 42 in. Plasma Television Logo
137 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
