Question about LG WM-2277HW Front Load Washer
LG 2277 Spinning intermittently "growling"
All afternoon I smelled the smell of something burning, almost like a plastic, emanating from the posterior of my washer. When I begin a washing cycle under normal load, the drum filled with water, but did not spin. Instead, it rotated about an inch before "snapping" back to the initial position. An LE error was issued.
Under test mode, the drum did spin, and a loud, unusual growl emitted from the washer, much like the sound of a motorcycle. All other tests were successful so I know it is not a pump problem, etc. Can you help me?
  • techwannabe Dec 24, 2007
    After researching a bit further it was worth the investment to replace the sensor assembly and see if this would fix the issue. Viola! runs like a champ. The part was located locally for a mere $ 25.00 and with a few tools, strength of a gorilla to move the machine I repaired it. Yes a mother of four can complete the job! The unit works beautifully and I still am glad that I purchased an LG!
  • Anonymous Mar 16, 2014
    The last load made a loud sound and the timer was stuck on same time. Wouldn't spin and started smelling of burnt rubber.
  • 1,294 Answers
Followup: (of techwannabe)
After researching a bit further it was worth the investment to replace the sensor assembly and see if this would fix the issue. Viola! runs like a champ. The part was located locally for a mere $ 25.00 and with a few tools, strength of a gorilla to move the machine I repaired it. Yes a mother of four can complete the job! The unit works beautifully.........................
Posted on Jan 04, 2008
Lg gas dryer something burning
burning smells in driers can be sometimes from a blocked lint filter. The dried lint has been known to ignite when it gets hot. If you haven't cleaned the lint filter then do so and if the smell continues get it serviced.
Nov 20, 2014 | LG Washing Machines
Printer smells
it may be ur power board.
discconnect it from power first and leave for 2hras
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
New lg tv plastic burning smell
I would contact the store you purchased it from,,,explain the issue and go from there...
Sep 20, 2017 | LG 42LG50 42 in. LCD HDTV
I'm getting a growling noise,seem to be associated with drive train.No vibration,just noise.Dos the transmission fluid need to be drained and replaced?
Firstly check the level of transmission fluid. Then check the color and smell. It should not be black and smell like something burned.
May 19, 2011 | 1994 Buick Park Avenue
LG washer 2277 runs fine but gives off a burning rubber smell
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2010 | LG WM2277H Front Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
LG WM-2277HW Front Load Washer Logo
460 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
