Question about GE WBSR3140DW Top Load Washer
Removing the busted dial
Beekay, thanks for this helpful suggestion. the washer is cleared out now, but I haven't been able to get the dial off. Presumably, I should grip it with pliers and pull back, but moderate force doesn't budge it. Is there a better way? Thanks. (And any suggestion as to where one might get a new dial? This washer was bought at Home Depot - do they carry parts?)
    Problem Solver:
  • 7 Answers
Dangwasher ---
Fix It Right's solution is right on the money. If you cannot pull the knob off, there has to be a retainer behind the knob.
Home Depot most likely does not stock the part. Look in the yellow pages for a local appliance parts store. MAKE SURE you have the Model # and Serial # written down. If you have a GE, there should be 4 screws on the top of the control panel. You may have to remove the screws to get to the retainer.
Posted on Dec 24, 2007
  • 262 Answers
If it is the timer dial just pull the heck out of it but some have a clip on the backside of the dial itself remove this pin and it will come off in your hand you can contact Ge aor repair or even a local appliance dealer ( Used or parts dealer) in your area can order it for ya
Posted on Dec 22, 2007
Have a whole house filter but dispenser sometimes works
Hello Greg, thank you for your post!
Based off the information you have provided the dispenser on your Electrolux washer works sometimes. This could be a possible issue with your water pressure in your home or the valve. There could also be a clog within the dispenser or line. I would recommend removing the dispenser and cleaning it out to assure there is no clog. You can place hot water in the dispenser on a rinse cycle to help clear the line out. If you continue to have issues with your washer I would suggest having a technician out to your home for proper diagnosis and repair. I hope that this information is helpful to some degree. -Matt
Feb 09, 2016 | Electrolux Washing Machines
Dial keeps turning
means busted circuits. replace/repair the control board.
Jun 12, 2011 | Splendide 2000S Vented Washer/Dryer
I have an older Hotpoint topload washer that the dial just spins. I am unable to set a wash cycle now. The dial is pulled out to stop the wash cycle, pushed in to start and to select a cycle. Can the dial...
HI, this timer mechanism is damaged, and i recommend the replacement of this defective timer control module asap. it can be accessed by removing the cover that is located behind the control panel. the timer is screwed onto the panel from the backside.
replacing this timer control module will correct this issue.
Sep 18, 2009 | Washing Machines
Replacing "Screw & Washer Lid Switch" on a Kenmore Washer Maching
remove the case. it sounds involved but is easy and really the only way to make this repair. chat me and I can walk you through it
May 10, 2008 | Washing Machines
RRemoving the washer starter dial
Yes, stop pulling on it. Axcess the rear of the timer there will be a smaller hole with a black piece of plastic inside where the knob shaft would be if it went all the way through. use needle nose pliers to grab the plastic piece and pull out. it is easier if the knob is pushed in is gets recessed a little more when you pull out the knob. The new timer comes with a new plastic piec pull it out then push back in to lock on the knob again.
Nov 23, 2007 | Kenmore 98702 Stacked Washer/Dryer
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Sep 07, 2007 | Ariston Technologies AW125NA 13 lbs. Load...
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
GE WBSR3140DW Top Load Washer Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
