Question about Logitech Precision Stereo PC Gaming Headset
Can i repair the cable on my headset myself. their is a short in the wire and no sound out of the left side Logitech USB with in line volume
  • 31 Answers
Problem is lately all the higher end headphones and usb sets use microthin wires. there is fine strands like as thin as a string and woven into it is 2 or 3 micro thin copper strands. it may be possible but very difficult...
Posted on Oct 04, 2009
Lg hbs 700 volume up/down, phone buttons not working
It sounds like you may have a broken wire inside. I would inspect the circuit board on the left side of the earpiece first. Look for shorts, broken wires or anything that looks burnt. You can use a multi meter to make sure the wires in the neck band are not broken. Here is the video showing how to open it up:
LG Tone HBS700 730 repair mod and upgrade
Sep 09, 2014 | LG HBS-700 Bluetooth Headset
Hear myself through my headset
so to begin
1. right click the lil speaker on the bottum right hand side
2. select Playback
3. Right click you default speaker set, (for me its 2-logitech G330 headset)
4. select properties
5. go to Levels in the tab menu.
6. use the microphone slider and slide the microphone volume to 0
hats it your done, your mic will continue to work as normal with out the feed back loop in ur head set.
Aug 30, 2012 | Logitech USB Desktop Consumer Microphone
Logitech headset problems
the problem is with cable(wire)...the insulation got failed nd got short circuited....if warranty period is there u can get it replaced with a new one...
Apr 05, 2010 | Logitech Premium Headset
I have a short wiring in my left ear cup of my Logitech Wireless PRO USB Headset, and sound out of that ear shorts out all the time.
Time for a new pair. If you are not handy with a sodering iron it is best to buy another set. Once the wires are broken inside the insulation the only thing that can be done is replace the wire itself. it is easy to break the wires inside the insulation twisting the cord, pulling or yanking the cord, along with blending the cord in a sharp bend acn damage this cords that they put on products today.
Sep 12, 2009 | Logitech Clearchat PC Wireless Headset
Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
Aug 25, 2009 | Logitech Premium Headset
Logitech Headset with micro phone
I got this from another page here:
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Mar 21, 2008 | Logitech (980590-0403)
Logitech clearchat pro headset
hello guys,
you have to update your audio card drives and vista updates should be upto date. then follow following options and you could find the solution there.
http://www.focusmp3recorder.com/images/fmr_vista_13.gif
Jan 15, 2008 | Logitech ClearChat Stereo Headset Headset
Logitech Precision Stereo PC Gaming Headset Logo
338 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
