Question about Canon PIXMA MP210 Photo All-In-One Printer
Error 2 When I try to print, E 2 flashes and nothing will print. Both cartridges are brand new, so that can't be the issue. I've tried re-plugging everything in and re-installing the ink cartridges. Is there anything else I can try?
    President:
  • 1,462 Answers
HI,
THe error E2-indicates no paper error
othe error codes:
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
Try resetting the printer,think this should solve your problem
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
RNJ VINODKUMAR
Posted on Oct 04, 2009
  • BROWNWIND215 May 12, 2011
    TO RNJ VINODKUMAR. still not working , Mine is the canon 250 and the alarm blinker is orange while the color blinker keeps flashing .The display shows O ,5 ,E in that order and just keeps alternating: what to do the printer is about 3 months old. Any advice will do ,PLEASE
    President:
  • 3,278 Answers
Hello !
There are 4 possible solutions to your problem:
1. Load paper correctly then press black or color button
2. Press on/off switch to reset the printer
3. Reset ink cartridge
4. The MP210 may require repair
Hope this helps.
Hi Does the Same hinge problem cause it not to print?? Because I have the same cover open issue. and when my x6570 will print nothing comes out on the page?? and its brand new ink?? Im pretty frustrated
The error could be due to the cartridges not properly installed on your printer. Try to open the printer cover and remove the cartridges > close the printer cover > re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds. > when the printer turns on, reinsert the cartridges.
Try to print again to verify that the problem is fixed.
Apr 29, 2012 | Lexmark X6570 InkJet Printer
Cartridge Error .... help!? I've read all the other replies and it's not helped!
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 14, 2012 | Lexmark X4650 InkJet Printer
My Lexmark x8350 has suddenly come up with Cartridge Error, Error #1203. I've followed all the remove cartridge, power off, power on, reinstall steps, but no good. I think it's the colour...
Hi Alan I think it is the cartridge that is causing your issue but I cant promise that it is.I can tell you from many years experience it very rarely is an issue with the printer breaking it is 99% of the time inferior consumables causing printers to fail, and sometimes wrecking printers so even when the customer does use good consumables it is too late and the damage is done, but we can't be sure of anything unless we start with basics and get 100% brand new Original Equipment Manufacturers carts (OEM) and stick them in. (no I don't work for Lexmark;)
Oct 31, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Error code Oxc18a0206 ink system failure
    I had this same exact problem. Try doing:
    1. Unplug the power cord from printer.
    2. Hold both o.k and Cancel simultaneously.
    3. Plug the power cable while holding the buttons.
    I had to go through multiple tries of the solution above. I turned it back on, it shut off and I turned it back on again. I tried to print something and sure enough, it did a maintenance cycle and it works again.
    This did not work the first time but after 3-4 times of doing both, TA DAH, it went through a lengthy maintenance cycle and then started working. Persistence paid off
    Jan 22, 2009 | HP Photosmart 3310 Printer
    Canon PIXMA MP210 Photo All-In-One Printer Logo
    714 people viewed this question
    old marine
    old marine
