How do you change oil gun in furnace to natural gaswe want to go to natual gas and don't know how to change the gun over
  • 80 Answers
You will need to call a professional to size the right orifice, inducer, and primary air intake for your application. If it is a residential unit you probably won't have much luck finding a conversion. Your best solution is replacing it with a gas furnace.
Posted on Oct 04, 2009
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Gas furnace is Not getting enough gas
Is this a new furnace? or possibly the furnace has been converted from propane to natural gas? Was it working correctly at an earlier time and nothing has changed since? Or was there a change such as fuel change or another appliance was added? Any specifics you can add will help. The problem says furnace is not getting enough gas, why do you think that is the case? In other words what symptoms are you seeing that lead you to that conclusion?
Jan 08, 2014 | Ruud Rheem Rgfe09ezcms Gas Furnace
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
CARRIER 58RAV NG GAS VALVE SPRING
Try national energy they are on line and sell spares for converting nat gas etc
Mar 26, 2017 | Carrier Grilling
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
Jun 17, 2010 | Barbeques Galore Turbo STS 4-Burner with...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Switch a natural gas furnace over to lp
WW Granger is the biggest supplier I know of for dayton. Consult them for information and if its still available.
In lue of this find the oldest repair man you trust and ask him if he knowes anything about them. I know I could help if I could see what you have and had some more questions answered. Pilot ignition? Gas valve model? Does it have a regulator in the gas valve? Then you have to find a kit to block open the regulator. Then change the orfices to correct size or solder and redrill the old ones. Then maybe adjust the combustion air, and you may have to change the pilot burner orfice and adjust it.
After that you can fill the LP tank.
Hope this helps IF so please grade me accordingly and Good Luck.
Mar 03, 2009 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
