Question about Iomega StorCenter (33349)
The usb is reading 0GB . it's and 8GB but format doesnt works TT
Hello. I have a really serious problem here, so i wish you could help me. I bought a USB 8GB in a store. and after 25 days or more... maybe because of virus or sth, it reads 0GB often and cannot display what's inside. and now i tried to format it. then in the end, it says: "the driver has not formatted successfully. How can i do. even before i bought i t too. is all 8GB like that? or..?? Any iDeas? THANK YOU for taking your time.
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 04, 2009
PROBLEM 0GB MAXTOR DIAMOND22 STM3160813AS
Your drive can be showing 0GB for a few reasons, if it is showing 0GB in BIOS, in Device manager or in any hard drive utility chances are the PCB is shot or one of the heads has stopped reading. In either case you will need the help of a data recovery expert if you wish to retrieve your data. If it's showing 0GB in My Computer but shows as 160GB(~155) in a harddrive utility or under device manager you simply require a software solution. If you require a recommendation for the professional recovery route simply reply back letting me know and telling me what country and state/province you live in, I can get you in touch with an appropriate service. If you simply need a software solution reply back with the drives original OS, your current computers OS and I can recommend a software package that will allow you to recover your own data.
Sep 30, 2014 | Computers & Internet
Hello bro My 8gb kingston pendrive is showing 1.97mb in my computer as its size? how to get back the 8gb size plz help me its urgent!!!!!!!!!!!!!!!
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
May 30, 2011 | Computers & Internet
Kington 4gb pendrive is not format & not working but appear
The actual memory chip inside it has failed = the stick is dead, replace it.
May 09, 2011 | Computers & Internet
0GB itouch
May be because you have used all the memory space your ipod touch had.
Oct 16, 2009 | Apple iPod touch
Wen i put my pny usb 2.0 drive in my computer doesnt read it
put it on another pc then check if it works or not if yes then format your card and ckeck it on your computer, i think its your flash drive problem.
Oct 12, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
V10, 8gb,transcend ,write protected
Hello sir,
If you want to format your pendrive and recover data..Transcend company provides there own software to make your pen drive perfect and working..you can get that on there website..or else here is the direct link http://www.transcendusa.com/products/online_recovery.asp
Aug 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My new 8gb sandisk says it is not formatted and I can't format it
well i heard on another website - that because the memory card can hold alot of memory, the computer doesnt accept it, so you need to use a usb memory card reader, ebay sells it for like £1
Mar 31, 2009 | SanDisk 8GB microSDHC Memory Card with...
Problem wit USB-port on DV-410
The 8GB is most likely what is called a SDHC or "Secure Digital High Capacity" It will not work in system that do not show they can read the SDHC drives, the 2GB is not SDHC
Apr 12, 2017 | Pioneer DV-300-K Player
Iomega StorCenter  (33349) Logo
428 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
