Question about La Pavoni LaPavoni Bar S3 Semi-Automatic Espresso Machine Espresso Machine
The machine makes a loud whistling noise when we try to make a coffee?
  • 1,711 Answers
The coffee solenoid valve can cause such a problem if it very old you must replace it
or the water pressure pump if the bypass it stuck and it produce more pressure than 9-10 bars no need to replace just clean or adjust the bypass.
Please remebr to vote for this answer thanks
Posted on Feb 17, 2010
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Mar 19, 2017 | DeLonghi Coffee Makers & Espresso Machines
My washing machine is making a loud whistling noise, with all the lights turned on when switched on
You have a bad connection or ground on pc board
need more info model #
is noise happens as it is running filling
may just have water supply not fully on this will cause a whistling
Jul 02, 2015 | Washing Machines
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Loud whistle
It is supposed to make loud wistle for good coffe , capuchino .
Oct 24, 2013 | Krups Coffee Makers & Espresso Machines
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
Make extremely loud noise when you first turn it on and it heats the water and again after each cup of coffee
This the water pump when is working. It should make loud noise. In extreme case in very loud but after a while it become less loud. If just consider that other smaler models have a smaler pump which is silent pump but they dont have it work always so in you case you a very good coffee result.
Jul 10, 2010 | Keurig B100 Coffee Maker
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine odea giro plus whistle while brewing
The scale in the pipe system have norrow at some points so while brewing and with hight pressure you here the whistle.
First I sugest to descale the machine and you may try to do it for three days repeatevly.
However if the noise will not decrease then the machine need full desasemble and remove the scale manualy. But I advice only to do the above if you have problem with the coffee quality or if the noise is so strong and can not bair it any more.
Jun 05, 2010 | Saeco Odea Giro Plus Coffee Maker
La Pavoni LaPavoni Bar S3 Semi-Automatic Espresso Machine Espresso Machine Logo
218 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
