Question about HP Mini 1000 Netbook
Restart by itself while working
I bought HP mini, after starting the computer, and after 15-20 minute, screen flash for error and restart the computer by itself. Please help, how to fix this problem.
  • 3,153 Answers
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
Thats because there are hidden screws.
You also have to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
Posted on Oct 04, 2009
  • Project NOMAD
    Project NOMAD Oct 04, 2009
    It could also well be some form of virus or spyware.
    It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
    It can also happen on graphic intensive applications.
    You should rule out nasty stuff first.
    MBAM !
    for a free one its pretty darned good !
    From a CLEAN computer download and put on a flash drive.
    Copy to your DESKTOP on the suspec computer.
    Run it but dont change any options just use what it offers.
    When its done let it clean anything it finds.
    Its where I always start with an infected machine.
    As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
    Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
    It may just be a "leaking application"
    These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
    May I suggest you download
    "hijackthis"
    It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
    They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
    Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
    If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
    "hijackthis"
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 13, 2016 | Computers & Internet
HP Netbook mini 110, Bought new battery but it will not reboot properly after installed
sounds like it is powered up if it is continually restarting. Does it work with the AC power adapter plugged in? At any rate the constant restart is indicative of a failing power supply (not meaning the battery but the power converter that is inside notebook). After the BIOS the PC goes to the hard drive for the boot cycle at which point there is an increase in power demand which can cause a weak power supply (not the battery) to shutdown and restart, hence the restarting cycle. How do you tell him to fix the problem?? well that depends but I don't believe that there is a conversational repair at this point.
Nov 11, 2013 | Dell Inspiron Mini 10 Netbook Computer
Need too restore to factory
The HP Mini laptop comes with either the Windows 7 or Windows Vista operating system.
You can restore the HP Mini to its factory settings using the laptop's recovery partition.
Restoring the HP Mini to its original factory settings will get rid of hard to eliminate viruses on the laptop's hard drive.
A factory restoration is also a good way to get rid of older files still stored on the computer that you no longer need and start with a clean slate.
Windows Vista
Click "Start" in the lower-left corner of your HP Mini Windows Vista home screen, then type "Recovery" into the Search box at the bottom of the Start menu. Click "Recovery Manager" in the list of options that appears above the Search box. The HP Recovery Manager will open. Click "Advanced Options" and then "System Recovery." Click "Next." Your HP Mini will restart. The HP Recovery Manager will open up automatically after the restart is complete. Click "System Recovery," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process begins. This could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista. Windows 7
Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager." Click "Recovery Manager" again to open the HP Recovery Manager program. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista.
b>
Feb 04, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
My Sister bought a hp mini 210-307nr pc, HELP!!
The two main methods in which to take care of Status Oxcoooooof Repair Screen error message:
Advanced Fix (manual update):
1) Start your computer or laptop then log on as an admin.
2) Click the Start button then click Programs, Accessories, System Tools, and next click Restore.
3) From the new window, click "Restore my system to an earlier period" then click Next.
4) Select the freshest restore point in the "select a restoration date" listing, and then click on Next.
5) Then click 'Next' on the verification window.
6) Restart the pc when the rescue is completed.
Inexperienced Computer User Resolution (totally automated):
1) Download the (Status Oxcoooooof Repair Screen) fix application.
2) Setup application and simply click on Scan button.
3) Hit the Fix Errors button once the diagnostic scan is successfully completed.
4) Restart your laptop or computer.
Here is a link to another Status Oxcoooooof Repair Screen recovery utility you can use in case the above option does not work anymore.
Nov 26, 2012 | Computers & Internet
I was trying to restore to factory settings. Now screen is Black background & has Windows/RM> and cursor is flashing how do I get past this point to restore
Restart your computer, press F8, advanced boot options menu will be seen.
1> Select REPAIR and then STARTUP REPAIR.
2> If it does not works then again restart your computer and press F11. Use the internal recovery partition to format the windows partition of your hard drive by selecting SYSTEM RECOVERY.
3> If it fails to solve again, use your or order a set of RECOVERY DISCS for your system.
It will solve every issue............
On faliure again, contact HP support centre, or your nearest HP/Compaq service centre
Mar 27, 2010 | HP Mini 1000 Netbook
I want to reset the settings on my hp mini to its factory settings.
Hello try to download the files on another computer running a Windows operating system and restore your
device, follow these steps:
1. From your computer, go to http://www.hpmini.com and download the
HP MIE Restore Image Creator utility and the HP Mini MIE recovery image.
2. Insert a USB flash drive into a USB port on the computer.
3. Launch the HP MIE Restore Image Creator utility from the Start menu.
4. Click the Browse button and select the HP Mini MIE recovery image.
– or –
Select HP Netbook Recovery Image to download the latest HP Mini MIE recovery image from
http://www.hpmini.com.
5. Click Start.
6. When the process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP MINI.
8. Change the boot order by turning on or restarting the device, and then pressing f9 while the “F9 =
Change Boot Device Order” message is displayed in the lower-left corner of the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Press enter again to begin restoring the device.
11. Follow the on-screen instructions to install the operating system and programs.
12. After the operating system and programs are installed, remove the USB flash drive(the device will automatically restart)
13. Restore your personal files and you are done
Good luck
Jan 20, 2010 | HP Computers & Internet
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Computer Restarts.
Most probably windows is generating an error and your computer is set to automatically restart when an error occurs. Try disabling automatic restart. right click my computer and select properties. click on the advanced tab and uncheck the automatically restart check box.
The reason why we need to do this is for us to see the actual error so that we will know what to do.
Oct 08, 2008 | E-Machines eMachines Desktop PC
HP Mini 1000 Netbook Logo
100 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
