Question about Whirlpool Washing Machines
Whirlpool lsr8233eqo machine won't agaite or spin will drain
Washed 2 towels and a bath mat machine became unbalanced stop and adjusted machine just growls
  • 38 Answers
Check belt,it mite of came off when unbalance.
or if it is a 2009 model,unplug wait 30sec. plug back in. hope this helps.
Posted on Oct 04, 2009
The mashine doesn want to go on 1200rpm spin. It just spin at slowly. Model: Series 6 Varioperfect
Mine does this if the load is unbalanced, usually when it's got heavy items in it like bath towels, mats etc. I have to stop it, open the door, rearrange the items and start the spin again.
Sep 07, 2016 | Bosch Washing Machines
Drains but won't spin. cycle light on spin. lid lock light off
if u don't have much in there add some more clothes, modern machines have a built in sensor that stops the spin if it thinks it will be unbalanced, it happened to me with just 1 bath mat was ok once I added more.
Jul 02, 2015 | Washing Machines
Whirlpool washer dryer not spinning one item
In fact there are sensors that can detect higher vibration and there by control the speed. It must be seen if this is available on your model. Please check the capacitor to the motor, couple a similar one and see if the speed improves. Also check for free movement with your hand , if not you need to reset the drive assembly.
finally check on the motor, check the drive.
Jan 20, 2013 | Washing Machines
Can't stop cycle
You probably have some other issue with the machine if it won't stop, but the machine may also not be spinning the mat out because the load is unbalanced. If you put it in on spin only, watch to see if it actually spins up to speed or not. You will see it rotate the drum back and forth a couple of times - it is sensing the weight of the load and trying to balance it. I the machine can't balance it, it will never spin up to max speed. If this happens, put a few other items in the washer with the heavy item (they need to be of similar weight - like some towels or a heavy jacket or something) and try again. Good Luck
Apr 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch Maxx (ref WFL 2450). stopped during wash and switch on
Remove the front lower panel, screws underneath. Drain off water. Be prepared for more water. Check filter for clogging. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 01, 2009 | Bosch Washing Machines
Washing Machines Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
