Question about Sony Handycam DCR-TRV840 Digital Camcorder
Lens does not zoom or focus error code
Lens does not zoom or focus. error code
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 02, 2010
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Les Error, cannot get in focus when in auto focus. I when itry and use the zoom I get a lens error and retry power on
the lens unit was not extend properly and cause of turning off once you turing on and zoom out.If you can open the camera and get the lens unit. Try to open the lens unit and clean it and try to rotate to the maximun position but dont put too much force. if you cannot do that bring it to service center
thank you
Jun 17, 2010 | Casio Exilim EX-S500 Digital Camera
Camcorder displaying Error 61
this is a lens error code.. In most cases iether the focus or the zoom motor is jammed. Pretty tough to free sometimes . But I useully will try it before ordering one or the other . They may not be available seperately but only as the entire zoom lens unit.
Apr 27, 2010 | Sony Handycam DCR-DVD205 DVD Camcorder
When i turn on the camera, it gives me an error message: the lens cover might be closed - E61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously (FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Mar 29, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Error 00-00-00 30-00-28
The error code will be due to bad batteries. Insert new batteries fully charged the camera will instantly try to zoom in or zoom out to adjust focus. If this does not happen then there is a problem with the Lens Assembly.
Lens has been forced due to an accident or too much sand or dirt is clogging it up.
You need to re-calibrate the focus.
Hope this helps.
Jan 26, 2010 | Ricoh Caplio G4 Digital Camera
My camera is showing the error code E:61:00
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Jan 16, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony DCR-DVD403 camcorder - picture won't focus. E:61:10 error.
E61:10 is a lens error code. You have a bad lens unit, but sometimes they can be fixed. The focus and zoom motor worm drives on the zoom lens jam when they get dropped. If your really really carfull you can free them up and fix the lens. Thereis a plastic claw that rides along the worm drive shaft that can get jamed. I've fixed thousands of these but i'm a guru. It can be tricky.
Dec 09, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Sony Handycam DCR-TRV840 Digital Camcorder Logo
53 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
