Question about ASUS M2N-MX Motherboard
Front usb ports
When I touch (not insert) a flash drive into a front usb port, the computer shuts down quickly-any thoughts?
    President:
  • 2,351 Answers
Follow the interior cabling of the front usb port to the Mb where its pluged in. Checking the cable as you go.
You'll need your manual for this. The pins are not in the correct order for "your" board.
Posted on Dec 22, 2007
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
WHEN I INSERT USB IN MY PC AFTER THAT MY PC IS SHUTTING DOWN AND THEN RESTART AGAIN? BEFORE MY PC IS NOT LIKE THAT! BUT NOW? EVERY I INSERTING USB IN MY PC ALMOST SHUTTING DOWN AND RESTARTING AGAIN?...
try to put your flash drive in the other port(back of the cpu)! then if it still the same problem! try to format your flash drive in other computer then if it still working i suggest you format your PC ^^
Mar 26, 2011 | Microsoft Windows XP Professional
Good Morning! Please help me how to restore the function of my laptop USB port, when i connect even flash drive, printer, scanner to my usb port it dosn't work properly, its hang then when i remove and...
Have you tried to shut down your computer and re-start it up again ? (to see if your USB port starts to works again ?)
One thing you should (must) do before you remove / detach a USB device (e.g. flash drive, camera, etc.) from the USB port is to make sure you properly "dismount" (eject/disconnect) the device first (e.g. use its Property menu option) before you physically remove the device (i.e. take it out - remove it from the USB port). If this is not done, you'll get the problems you're experiencing.
Jan 02, 2011 | Computers & Internet
Inserting my flash drive in USB port, in my win 7, does not create a new letter in my computer. Why?
Try a different USB-port in your computer.
Try connecting some other USB-device (mouse? keyboard?) into that USB port, to confirm that the USB port is OK.
Try the flash-drive in some other computer, to confirm that it is OK.
Check your Windows 7 "setup" to see if it is blocking the attachment of USB-devices -- this is common in a workplace environment, where the computer is "locked-down".
Oct 29, 2010 | Computers & Internet
Flash drives inserted in usb ports shuts down
make sure there is no virus in flash drive boot the system in safe mode and run complete scan the system and flash drive.
Jan 14, 2010 | Office Equipment & Supplies
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Maxtor one touch mini doesn't appear to work.
The blinking light indicates something is happening to know open :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=1600
And check the power cord and try with the known good power cord.
You can check this :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=SzkLKr3j&p_accessibility=0&p_redirect=&p_lva=1600&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTg0LDE4NCZwX3Byb2RzPTQxMCw0MjEsNDYxLDQ2NSw1MDgmcF9jYXRzPSZwX3B2PTUuNTA4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Feb 16, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
ASUS M2N-MX Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
