Question about Frigidaire Affinity ATF7000ES Front Load Washer
Error code E20, I have checked hose for blockage/kinking and used drain opener on household drain, still not spinning to damp/dry and still displayng error code E20
  • 10,515 Answers
HI,
e20 error means Long drain. There is a coin catch located in the hose from the tub to the drain pump. You need to remove the hose and clean the filter. You can do this by removing the back panel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2009
I have a Kenmore 110.4751 It will periodically beep while washing clothes. I don't find any error codes visible. I don't find any explanation in the manuals for this condition.
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
My front loader is not working whirlpool
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite beeps all the time
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE5 Dryer beeps while running
Aug 14, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Does not complete program
Mar 15, 2009 | Kenmore Washing Machines
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
Feb 17, 2009 | Washing Machines
Kenmore elite washer cycle signal keeps going off an on turing cy
Jan 04, 2009 | Kenmore Washing Machines
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Error code E20. This is not listed on the error code chart. What do I do to fix the problem.
E20 means the drain hose is plugged or kinked or the household drains are plugged. YOur washer will not drain and spin until this is fixed.
turn off the washer/unplug it/remove the drain hose and check for a clog. If it is there, clean it out. If not - check your sinks and toilets for slow running drains. The garbage disposal is a good place to start as well. plug the sink, fill it with hot water, then pull the plug and start the disposal. That will help clean the disposal and also show you if you have a drainage problem there. Plunge the toilets, etc.
Good luck to you!
Aug 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
299 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
