Question about Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLR5667w , replaced humming color wheel, clean the dust out, everything seemed good. Now after closer inspection the colors seemed to be pixelated. Hi def channels seem better then regular channels, but not a 100%.
  • Samsung Master
  • 5,138 Answers
Dont be surpised when its Light Engine next Encompass 1-800-638-3328
Posted on Oct 04, 2009
Keeps cutting off, also humming noise
Most likley cause is the color wheel is broken.
Mar 18, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
I have a samsung HL-R5667W . It has started to wine really bad like a fan is going out . then the picture started to flip colors before it went out. if you let it cool down it will play for a short while...
Ur tv have a colors wheel design it it.100% ur colors wheel is dead,require replacing.Huming or winning motor noises or colors fades flips or flashes black&white wthin pictures.The colors wheel is the causes and dying not spinning inside it motor axis anymore.The colors wheel sit way back of the tv,require take out alots of the tv manchanical parts out,before it can take out and replace it.U have no machanical skills don't tries this.Hire a tv tech. to replace the colors wheel.
Jan 13, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Would a DMD board make a loud humming noise if it went out?
No, it will be the Color Wheel PN# BP96-00674A
Encompass Parts Distribution 1-800-638-3328 $123.33
Mats had CW for $95.00 1-800-628-1118
Samsung Parts 1-800-627-4368
Oct 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I've a Samsung DLP Model HLR-4266WX that has started to hum and is distorting the picture. I've replaced the cooling fan on the heat sink in the back and that didn't work. Is there another fan in the set...
Color wheel would be cause of hum noise and distorted picture on screen.
Please note that color wheel is not user level repair and requires expertise because it is located in light engine, the most sensitive and expensive part of dlp tv.
If you are good with electronics stuff fix then have service manual copy in hand to start inspecting color wheel.
Aug 26, 2010 | Samsung DLP HL-P5663W 56" TV
My samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Jan 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Pic freezes, goes dark w/sound then back on
By what you have said your color wheel can cause this when it stops running .Pull back off and watch what is happening when you turn set on.
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Won't turn on
Make sure that you have the orange flat cable turned the right way when you plugged it in. I accidentally turned one the wrong way and that was the response I got. Hope this is all it was if this does not fix it I would measure the ballast and make sure the 200 or so volts is coming across.
Feb 07, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
258 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
