Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung Projection TV
I bought a demo model earlier this year and now the tv goes to black and white after only a few minutes of being turned on. I can shut it down for a few minutes and it will be in color when I first fire it up, however, after a short amount of time it goes back to black and white. is this as simple as replacing the lamp? Muchoo Tnx!!
Reards,
dave
  • 1 more comment
  • jsa22 Apr 24, 2008
    My Smsung Model # N5065W has no picture or sound.Just a black screen.The projection light and fans are running.The lamp light on the front blinks on an off then the tv turns off.HELP. It is just to new to give up. Someone said the Transformer,I don't think so.Fuze is good.Joseph
  • Jim3d Apr 29, 2008
    No video. sometimes when pulling input line out it blinks on, then off. the sound is good, but video will not play on any of the inputs, including antenna. Sansung HLN5065W.
  • SaschaRory May 11, 2010
    Could you please provide a picture of the DLP chip on the board and how to remove it? Thank you
    Problem Solver:
  • 8 Answers
You need to take out the DMD bord and open it up then remove the DLP Chip very carefully and blow out under the chip and all the components in the box with dry air something with a dryer on it then reassemble the chip on to the bord and make sure that the three screws that holds the mount that houses the chip are snug then you will need to put the Bord back in and have someone Else watch the pitcher so you can center the pitcher. This happened to me with my samsung tv and ran across this in sum service notes for this problem. Hope this helps
Posted on Jan 02, 2008
The color went out so that now it is black and white. If I turn off the tv for a few minutes it will go back to normal. Then after being on for a few minutes it will change back to black and white. If you...
This is unusual for this model, can you tell me what source you use for signal? Cable? Sat? Direct TV? Also how are you connected----via the coax fitting or the rear AV jacks.
Steve
Nov 01, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Nov 16, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Jerry Greenberg
Jerry Greenberg
