Question about Cameras
I have a Coby snapshot cam i have no cd and i want to put it on my laptop windowes vista so please help me out
Acer orbi cam
Hello!!
Install the webcam drivers from the cd which has come with the webcam ..
Feb 23, 2009 | Acer Aspire 3680 Laptop
Tip
System Restore Via Recovery Console
<br /> Ever encountered a problem with your computer wherein it gives you an error page saying that a certain file in the registry is missing or corrupt? Unfortunately, with this kind of error, there are times that you are not able to boot into the OS, and therefor you are not able to do a system restore. <br /> If you are using Windows 7 or Vista, you may initiate System Restore via booting into "Repair My Computer" which you can choose via the Advanced Boot Options of Windows. However, what do you do if this does not work, or you are using Windows XP. <br /> Fortunately, there is still a way to be able to restore your system. This involves manually doing the system restore via the recovery console (for XP), and recovery environment (Vista and 7). The only thing that you will need is the OS CD. <br /> Once you have successfully booted into the Recovery Console, type in the commands below and make sure that you press "ENTER" after each line. <br /> <br /> C:\WINDOWS] cd \ C:\] attrib -h-s "system volume information" C:\] Cd "system volume information" C:\system volume information] cd _resto~1 ..._resto~1] dir --- this should list several rp folders [short for restore points] just select second to the last or any of your choice other the the last rp folder ..._resto~1] cd rp# ...rp#] cd snapshot ...snapshot] dir --- the 5 hive files are shown in this format: _registry_machine_software _registry_machine_security _registry_machine_system _registry_machine_sam _registry_user_.default Syntax [Command filename location] ...snapshot] copy _registry_machine_software c:\windows\system32\config\software ...snapshot] copy _registry_machine_system c:\windows\system32\config\system ...snapshot] copy _registry_machine_security c:\windows\system32\config\security ...snapshot] copy _registry_machine_sam c:\windows\system32\config\sam ...snapshot] copy _registry_user_.default c:\windows\system32\config\default ...snapshot] exit <br /> After this, you just need to restart your computer and it should be working fine.
on Jul 25, 2011 | Computers & Internet
My laptop wornt read cds or dvds nor my logitech web cam
na thats not the issue the drivers are not able to install properly uninstall the drive from the device manager and restart the system it should pick the right drivers ... if that doesnt work update the system with the windows vista service pack1 it will download when u start the windows update and regards to ur webcam u should be having the driver cd for that install the driver capable for windows 2000 and that should work
Feb 09, 2009 | Toshiba Satellite A135-S2386 Notebook
Snapshot related
Press CTRL+Print Screen. Open a jpeg viewer like Windows Paint or MS Word. Then press CTRL+V to paste the snapshot. Save the file and send it.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
Acer orbi cam
most probably you have a cd utilities enclosed in your pc. You have to insert the cd and then install the driver for the orbicam . hope this will work.
melnavz
Oct 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
My web cam
You can download the drivers from GENUIS's site:
For Windows XP
For Windows Vista
Hope that helps!
Sep 06, 2008 | Genius VideoCAM Eye Web Camera
My windows vista built in cam
Go to this link here.
All of your drivers are on this link above. You might want to download all of them so you will have them in the future. Back the up on a CD and put them in a safe place. You can also order a recovery CD from ACER. Your laptop was made by ACER.
After you download the driver you might have to put it in a folder for it to be stored in. After you put it in a folder, unzip it in that folder and it should have an .exe file. Click on this and it should do the install. If it does not do your install you can go to the Device manager and click on the device and tell it to install or upgrade the driver. Then you will need to direct it to the folder where you have the unzipped file. This should correct your problem.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya. I did more than try; I sent you exactly to where you could get the driver and explained how to install it.
Jun 04, 2008 | Computers & Internet
Acer orbi cam
try it by re installing the driver or by installing the cd-rom which came with the cam...................
Feb 26, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer orbi cam
First connect the cam and then insert the cd. Now open it in that click the setup and click next to continue to install.
Feb 25, 2008 | Acer Aspire 5100 Notebook
How to download pics from inovix dvz 500 to my laptop working on windows vista?
the diver cd comes along with th cam does not have vista drivers so as to support the cam . go to the cams company website > support section and downlaod the drivers for vista if its available
Dec 22, 2007 | Cameras
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
