Question about Kodak EasyShare Z7590 Digital Camera
Picture printing problem
When trying to print pictures, only the right half of the picture shows up.
SOURCE: Difficulty reviewing pictures when camera docked
Had the same thing happen. You must use the arrows on the dock, not those on the camera.
Posted on Jul 28, 2007
Bubbabear64
  • 2794 Answers
SOURCE: file corrupt
It could be something going on with the memory card. Do you have another way of loading this card up into your computer or can you take it to a drugstore or Wal-Mart and see if it reads into the photo computer?
Posted on Jun 16, 2008
  • 31 Answers
SOURCE: Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
  • 32 Answers
SOURCE: My printer is only printing half the picture, one
  1. Remove the power cable from the printer.
  2. Remove the paper tray from the printer.
  3. Remove the paper from the paper tray.
  4. Verify that the paper you're using has KODAK XTRALIFE Paper
  5. Insert the paper tray into the printer.
  6. Open the color cartridge door, then remove the color cartridge.
  7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
  8. Install the color cartridge, and verify that it is fully engaged.
  9. Close the color cartridge door.
  10. Connect the power cable to the printer.
  11. Wait for the printer to initialize (the paper may eject automatically).
    NOTE: For the Photo Printer 500 and the G600 or G610 Printer Docks only, press the power button in addition to plugging in the power cable.
The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
If the problem persists cal 1800 2356325 > for a repair
Posted on Oct 28, 2009
leepania
  • 1099 Answers
SOURCE: Kodak Easyshare Z740 printing problems
In order to help you with your printing problem I need the model of the printer and not the camera.
If it helps here is a link to the online printer help tool:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
I hope it works out
Posted on Feb 09, 2010
Only half of the picture prints on my selphy cp 730 canon printer
Nov 01, 2014 | Canon SELPHY CP730 Thermal Photo Printer
Why does my cannon cp-200 printer only print half the image already changed ink cassette
it is probably set to print a certine size of the photo, can you do a print preview before printing and see what that looks like, then check all your print settings.
Sep 13, 2014 | Canon Office Equipment & Supplies
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Aug 12, 2014 | Sony Picture Station DPP-FP90 4x6 Photo...
Picture only prints on one half of page
Try printing a testpage just press print + cancel and make sure you have a paper loaded
Nov 15, 2008 | Kodak EasyShare Thermal Photo Printer
Prints partial picture
You have to rotate the pictures 90 degrees if they are landscape before printing.
Jun 10, 2008 | HP Photosmart 4180 All-in-One Printer
Only half of picture is printing
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
Mar 20, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Kodak EasyShare Z7590 Digital Camera Logo
13 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
