Question about Husqvarna Viking 1
I have a mega quilter and keep getting rat's nest on bottom.
It will be sewing along great and then have a horrible rat's nest. I then have to stop and cut those out and start again. It is intermitant and driving me crazy. Any help?
    Problem Solver:
  • 5 Answers
The rats nests that you are describing I assume are on the bottom of your work. If this is the case, it tends to generally be caused by incorrect tension from the upper thread, or incorrect theading of the upper thread.
Occasionally the tension of the bobbin could also be out.
As a rough guide the tension of the thread as it leaves the bobbin should be that it needs a gentle pull to release it. If you were to hold the thread only & let the bobbin hang, it should only release if you were to like shake the bobbin toward the ground. Anything other tension would mean adjustment of the bobbin screw.
A lot of upper tension problems are often caused by the tension settings being incorrect, the wrong mix of threads/fabric, blunted needles, threading of machine whilst pressure foot is lowered (very common), and sometimes by dirty machines that are not thread and lint free or infrequently oiled.
If all that fails, you need professional service help as it could be a timing issue possibly.
I hope this gives you a few things to try that may help before you need to spend money on your machine being fixed, however remember that a regular service will ensure continued happiness from your machine
Posted on Oct 04, 2009
Bottom thread is a tangled mess. Was going great, now can't sew.
bottom thread mess is an indication that the needle thread tension is too loose
check the needle /hook timing to ensure that it hasn't altered
Jun 28, 2015 | Singer 6180 Brilliance 80-Stitch Sewing...
Husqvarna mega quilter
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
Apr 26, 2014 | Sewing Machines
Get a rats nest when I start sewing
I am not sure, but you can try this:
when the tension of the thread obove is loose, it jams down. Different fabrics call for different tension.
Try tightening it buy screwing colckwise above the needle. Use a piece of fabric to investigate the best tension for your proyect.
Wish you luck.
Dec 15, 2013 | Janome Memory Craft 4800QC
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
Needle sticks on sewing machine and motor won't move it forward
Copy & paste into your browser: http://fixsewingmachine.com You need the free diagrams & details provided on their web site. Jimmy
Apr 05, 2012 | Montgomery Ward Sewing Machines
HV mega quilter hand wheel won't turn and it won't turn on
it could be the switch or motor, it would be a good idea to have the machine checked
Apr 05, 2012 | Sewing Machines
Rats nest on back of fabric
make sure the machine is threaded according to the operations manual & the tension adjustment is according to the operations manual says
make sure the needle is not bent, and also the correct needle for the machine & fabric
if none of these work it needs to be taken in to be check
Jul 18, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have a Husqvarna Mega Quilter Viking. The
If you're sure you're using the correct needles, you should take it to a service tech to align it properly.
Nov 01, 2009 | Husqvarna Viking 1
Sewing Machines Logo
198 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
