Question about Proscan 26LB30QD 26 in. LCD HDTV
No sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
I am using composite wires (yellow, red, and white). The video is just fine, there is just no sound. I have tried all different configurations of the wires in the back, but still no sound.
    Novelist:
  • 128 Answers
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
Posted on Oct 07, 2009
How do I hook-up a dvd/vcr.
Hello dgrant13,
All you need to do is use a composite cable, or known as RCA cable (the red, white, and yellow cable). Both ends of the cable should have red, white and yellow. You just need to find the red, white, and yellow on the back of the dvd/vcr where it says audio/video out (AV out). Then match the colors and plug one end to the back of the dvd/vcr and the other then (matching the colors) to the Proscan tv where it says audio/video in (AV in). Good luck.
Joe
Aug 28, 2011 | Proscan 32LA30Q Television
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Dvd movies won't play in color, are my connections wrong?
in most cases its the tv not the player make sure the tv is set to nstc not pal
Dec 28, 2010 | Samsung HT-X50 System
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a friend whose Emerson Flat Panel LCD television works fine except when you hook up a DVD Player to the television set it only shows the movies in black and white. For some reason I can not get it...
How do hook it up? Are you using composite video (Yellow video cable) from DVD Yellow RCA video out to the TV AV1 composite video Yellow RCA jack and RED and WHITE cables for sound. Or you are using component video hook up using RED, BLUE, and GREEN Video cables and the RED and WHITE cables for sound. Please post back and tell us how you have it set up. You just have to match the color of jacks and plugs, unless there is problem in the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Emerson EWL3706 37 in. LCD Television
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Proscan 26LB30QD 26 in. LCD HDTV Logo
269 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
