Question about Whirlpool GBD307PDS Electric Double Oven
Whirlpool gas range model sf385pegq
Oven turns of and get an error message E2 F1
    Scholar:
  • 196 Answers
Analog to digital failure. Replace the control board.
Posted on Jan 26, 2008
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
E2 f1 errors
E2 F1 is a fault code for electronic sub system failure you are going to have to change the main clock control assembly; enter your part or model number for best results: repairclinic.com/Oven-Control-Board
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Make sure your control board is the correct one.
Hope this helps.
May 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
We turn oven on to heat and get E2 error code and then F1 error code where cook time should be displayed
Hi dear.Here is what you can do: F1 - E2
UL A/D error(s)
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
I hope that helps.Thanks
Aug 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 | Ovens
Whirlpool gas range/oven #GS395LEG
I turned the auto clean on, then immediately opened the door to get the racks out. Now the door lock is out and the oven won't work. How can I get the lock to go back?
Dec 24, 2007 | Ovens
Whirlpool GBD307PDS Electric Double Oven Logo
268 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
