Question about Microsoft Windows XP Home Edition
Can`t get windows to start i was installing system mechanic 8 it ran some tests up pops a banner saying windows won`t restart. i can`t get it to reboot
  • 558 Answers
Well the software corrupted windows and you might want to restart in safe mode copy all your data reinstall windows.
Good luck
Posted on Oct 04, 2009
  • 3,153 Answers
Shut it down forcibly.
Restart and boot into safe mode by repeatedly pressing F8
Once in safe mode use the system restore option to go back to a time when it ran OK.
It should then restart and you should be OK.
If you cannot do a system restore then do the F8 type restart again but choose last known good configuration and try that way.
Hope this is of use.
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
~pop up and other things
you may have a virus or trojan; msn msnmesunserv, messenger spelt wrong is a clue (mesun), turn off system restore (so as to stop virus backups), then restart your pc in safe mode F8 on boot up and select safe mode, then run your anti virus and anti spyware programmes. restart the pc and turn system restore back on, then click Start>Run, then type msconfig, then press enter. Go to the start up tab and look for the msnmesunserv programme and untick it. restart pc again and then tick the window that pops up saying you have changed settings and not to show again, it should then run ok.
Sep 28, 2007 | Dell Microsoft Windows XP Home Edition
How do I install Bernina Artista Software V5 on Windows 8?
Contrary to what Bernina has said about their software (Bernina Embroidery Software v5), that particular software CAN be installed AND ran in Windows 8 with no issues whatsoever. When you install it, it will perform normally (not go to a blue screen like Bernina says), then it will ask you to insert the dongle. After installation, go to the Bernina Embroidery icon and right click. Select troubleshoot compatibility. The computer will run a test to see what system you should run the software as. It should say Windows XP Service Pack 3. Select next. Now double click your Bernina software and it should start up fine. Hope this helped.
Dec 30, 2012 | Bernina Sewing Machines
I just installed an update to my System Mechanic program and now when I try to open the program a window appears telling me i must restart my computer to fininsh the update. I have restarted twice and the...
You may do the update once more and see if you are getting the same message. If so, start the computer in the safe mode and disable automatic updates and restart
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Aug 21, 2011 | Iolo Technologies System Mechanic: Windows
MY 2002 DODGE GRAND CARAVAN, 3.3 started out by stalling. we took it for diagnostic, mechanic said catalytic convertor bad. changed that and coil. changed map sensor, both O2 sensors. took it to another...
does the van stall going down the road or at idle? the won't change gears at 4000 rpm and the no start condition unless disconnect the negative cable sounds more like a computer problem. when the cable is diconnected the ECM and the TCM have to go thru a relearn process which can be some of your issues. have your mechanic do a quick learn on the trans module to see if it helps the shifting problem. the ECM on the other hand can throw out codes that can make you chase your tail and end up replacing every sensor and still have the smae problem. you may want to check for corrosion at the ECM connections.
Jul 19, 2011 | Dodge Grand Caravan Cars & Trucks
I have lost the use of internet explorer - I get a run time error. I have tried to download from their website but my system says there is a newer version already loaded so it won't load the one I down...
Steps for Windows 7To uninstall Internet Explorer 8, follow these steps:
  1. Close all programs.
  2. Click Start vistastartbutton.jpg, and then click Control Panel.
  3. Under Programs, click Uninstall a program.
  4. In the tasks pane, click Turn Windows features on or off.
  5. In the list of windows features, clear the check box next to Internet Explorer 8.
  6. You receive a warning message in a pop-up window. Click Yes.
Internet Explorer 8 will now be uninstalled. The system will restart after the installation.
if that fails then there is a manual way to do this using the CMD prompt...
  1. Carefully select and then copy the following command: FORFILES /P %WINDIR%servicingPackages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"
  2. Click Start, and then type Cmd.exe in the Start Search box.
  3. In the list of programs, right-click Cmd.exe, and then click Run as administrator.
    Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  4. Right-click inside the Administrator: Command Prompt window, and then click Paste to paste the command that you copied in step 1.
  5. Press ENTER to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base:
Jul 30, 2010 | Dell Inspiron 1720 17" Widescreen...
Explorer 8 removal
Steps for Windows 7 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start Collapse this image Expand this imagevistastartbutton.jpg, and then click Control Panel.
Steps for Windows XP or for Windows Server 2003 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    Note If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
  5. Follow the instructions to uninstall Internet Explorer 8.
Please rate the answer. Thank you!
Apr 27, 2010 | Microsoft Internet Explorer 8
Xp blue and black screen
It seems like you had a software conflict...
Jan 12, 2008 | Microsoft Windows Xp Home Edition English...
Microsoft Windows XP Home Edition Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
