Question about Bryant Heating & Cooling
It blows the circuit breaker. after resetting it blows out warm air through vents in the house
    Sergeant:
    Champion:
  • 215 Answers
It sounds as if you have a freon leak, and that is where the hot are is coming from, I had a brand New house and the first year I had to replace the compressor on the condenser unit, I was lucky , mines was still under warranty
Posted on Oct 04, 2009
How to change fuse in LG Trom dryer circuit breaker model DLE2514W
dryers don't have circuit breakers in them you do have them in your house fuse box,you must mean like the thermal fuse or high limit fuse,if the dryer isn't running these are the things you want to check,also if the dryer and vent line haven't been cleaned out and you might have noticed that it was taking loner for your clothes to dry,this will blow one of the t-stats as a safety,all a dryer does is move air,if you have a block in the dryer or vent line one of the fuses pop from the dryer heating up to much from the block so clean out the dryer and vent line before you run the dryer again if you fix it because the t-stat that was blown will blow again.
Jan 15, 2018 | LG Dryers
Dryer turns on but does not get hot or even warm for that matter
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 27, 2011 | LG DLE1310 Electric Dryer
Dryer tumbles,blows cold air no heat,looking for access to fuses,dont know what part of dryer fuses are located
Feb 26, 2011 | Dryers
Kenmore 80 series dryer approx 7 years old not heating anymore. Cleaned the vent pipe using semi-rigid vent tube only three feet to outdoors. Vent on exterior blowing cool air forcefully. It is an...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a link to a video that will help you.
Nov 26, 2010 | Dryers
Heatpump blow out air put not warm
We will need to check and see if the outdoor unit is running when thermostat is set for heat. If not, check the circuit breakers and reset if tripped. Also, check to ensure the high pressure switch isn't tripped (you will likely need to open the panel to see the HPS, it will have a red button on the top of it.
Mar 22, 2010 | Heating & Cooling
My heat and air conditioning wont blow out through the vents
Check the air handler to see if the blower is on. First check the circuit breaker which gives power to the blower.
If the condenser outside is not on, there is no power anywhere. Again, check the circuit breaker.
Also possible faulty thermostat.
Mar 05, 2010 | 2004 Chevrolet TrailBlazer
HEater is heating outside but not blowing warm air thru the vents inside the house. May blow air for 10 mins but then stops. I have the temp. set at 76 degrees but it is 48 degrees in my house right now.
sounds like you may have some restriction in the heater or overtemp sensor is kicking out to soon, clean everything thourghly, check fan and oil bearing, check safety circuits in furnace wiring, refer to owners manual trouble shooting guide
Jan 30, 2010 | Goodman GMS90703BXA Heater
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Jan 10, 2008 | Dryers
Heating & Cooling Logo
59 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
