Question about American Standard Heating & Cooling
Water collected in the tray under the air handler. The float turned unit off. Drained water and AC returned. What caused the water to collect in the catch tray. Is there a clog in the drain pipe?
    Sergeant:
    Champion:
  • 215 Answers
Yes there is a clog in the drain, you can try a cloth hanger or a small drain auger, slug builds up and clog the drain it only takes a little to clog the flow and can easily be unclogged
Melvin
St Louis
Posted on Oct 04, 2009
Why is water comingboutvthe bottom of my triano air conditioning unit
air conditions work by removing water vapor from the air
that water is collected in a tray to be drained out
if the drain is blocked then that water will run out onto the floor
Jul 24, 2016 | Cars & Trucks
Where is the defroster
Defrost on most units works like this. An electric wire heater is embedded in the cooling coil where the air is cooled. A timer periodically shuts off the refrigerator and turns on this electric heater coil which melts the frost off the coil. The water from this defrost collect s in a trough below the coil and drains down thru tubes into a shallow plastic tray under the unit. The water does not collect there but is evaporated over time by the hot air that blows over top of the water by the fan that comes back on when the refrigerator returns to cooling cycle. This is the fan that sucks air from the room over the condenser coil under the fridge to make the refrigeration work. The air is warm after passing over the condenser coil and then the air passes over the water tray. You can feel the warm air returning back into the room if you out your hand down near the floor.
Mar 16, 2014 | GE GSS20IEP Side by Side Refrigerator
No 24 v to contactor
The thermostat is the device that determines when the A/C unit starts up. It will require a 24v source (transformer most likely in the air handler) to provide power for the control. If the 24V is present, and the t-stat is calling for cooling, then there is probably a safety device preventing it from starting.
One such common safety device is a water level or "float" switch that detects water level in the pan under the air handler. These are most often found in homes that have the air handler in the attic space. Normally, these pans a dry or have a a few dropsof watrer in them. Condensate is created when warm, humid air is passed over a cold coil. It is collected and routed outside. If there is a problem getting the condensate down the drain pipe in the air handler, it will drip out of it onto the attic floor. This is why a shallow pan is installed under the air handler. The pan will collect the condensate and is piped outside and down to the ground. If the pipe has become clogged - preventing draining - the water would overflow the pan and ruin the ceiling in the space directly below. The float switch prevents the signal from the thermostat from turning on until the water has drained to a safe level.
Check the pan - if it is empty, the switch may have been distrubed and actuated - even though there is no water in the pan. Operated the switch to make sure it can move freely. There may be other safety devices inline like the float switch. You'll need to follow the circuit and find where it is being interrupted in order to make the repair / correction.
I hope this helps & good luck!
Apr 10, 2013 | Heating & Cooling
I have an kenmore elite A100E portable air conditioner. I have two questions; 1- It drains water from the back pipe outlet which makes my floor wet. How to collect this drained water to stop it damaging...
Yes is does work as a dehumidifier, when it's in dehumidifier mode. Using just the AC mode, will slow up the collect ion of water some. However, the tank will still need to be drained occasionally. There are 2 ways to train the tank.
1. In to a low sided pan or bowl, capable of holding at least 1 quart of water.
2. Roll the unit to a floor drain or outside to drain the bucket.
Hope this helps and thanks for choosing FixYa.
Jul 31, 2011 | Heating & Cooling
Our fujitsu reverse cycle AC is leaking water at bottom left hand side of the internally mounted blower unit
Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Feb 01, 2011 | Fujitsu 24C1 Air Conditioner
My Delonghi A120LE Drips water not sure why
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Jul 16, 2010 | DeLonghi A120E Air Conditioner
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Jul 07, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Water in the Unit
Most of the AC Unit lately are not made to drain. So when you have water collecting inside the unit, the condenser and the evaporator is suppose to help dissolve the water.
When water is collecting inside the appliance like that, it is either because the ac unit is not installed correctly or you live in a high humid area.
Aug 06, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
321 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
