Question about Sharp R-230 Microwave Oven
I cant use the defrost function on my microwave
I get an EE error when i try to defrost with my "sharp carousel microwave"
MicrowaveSvc
  • 9098 Answers
SOURCE: manual for sharp carousel R-230 AV
Models R420D and R520D also have this common feature found on Sharp microwaves. You can download that manual free at the link below (not my link) and the section on Compu Defrost should help you just fine. http://www.htsarebates.com/files/mic_man_420,520D.pdf#search=%22sharp%20compu%20defrost%20filetype%3Apdf%22 Or you can just do the Google search below and you'll end up with a list of several manuals you can try: "sharp compu defrost filetype:pdf" (without the quotes)
Posted on Sep 21, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
The service manual (available at our site) shows how and shows that the lamp is mounted in the air duct near the magnetron. See http://www.microwavedisplay.com/r510hk_hw_sm.pdf
Part # is RLMPTA086WRZZ and you should be able to get that generically locally but if not, you can get it form Tritronics at http://www.wehaveparts.com
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Posted on Oct 13, 2008
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
How do I set this microwave to defrost a whole frozen chicken - 4.5 lbs?
I wouldn't. Let it defrost i the fridge or if you are in a hurry, cold running water in a bowl in the sink. Microwave ovens cause warm spots and a health hazzard
Mar 08, 2011 | Sharp Carousel R530EST Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Jun 04, 2009 | Sharp R-1870 Convection/Microwave Oven
Defrost instructions
First of all, this model and R-4A92 and R-5A82 are very similar.
You can get the manual (# IB-R4A82) from Tritronics at http://www.wehaveparts.com
If you don't wan to do that, please reply back and I'll outline the basics of how the defrost functions worked on ovens from that era .
Mar 10, 2008 | Microwave Ovens
Manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
Sep 21, 2006 | Sharp R-230 Microwave Oven
Sharp R-230 Microwave Oven Logo
134 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
