Question about Sony Televison & Video
Red green blue colors are not in-synch on screen, end up with multiple pictures. is this easy fix?
  • 110 Answers
In your menu you should have a setting for convergence. this will allow you to shift each color to re-align them. If this does not work you will need to have qualified service center help you.
Posted on Oct 04, 2009
Picture is black and white, but I have sound. I have red, green and blue plugins. The green one is fine, but I'm not sure which spots to put the red and blue wires in to fix the color.
blue is always in the middle and the green / red are on the ends. Black / white means you have the wrong matching cables. You need to make sure to match red to red, green to green, blue to blue.
Sep 09, 2011 | Sceptre Televison & Video
How do you know if you need to replace the fluid? can you show me some pics of good red green blue color or some bad colors
If the glycol is bad, there is a easy way to tell:
Remove the back cover and with the set on use a small mirror--put it over each of the three Lens--red will never be bad this way.
What you want to see is a green picture on the green tube and a blue picture on the blue tube.
If instead of a picture either the green or blue look like a floodlight with no picture--the glycol is contaminated.
What happens is bacteria grows in the blue or green glycol--never the red--for some reason it does not like the red color.
Usually the blue will be the one first affected---picture will have a yellowish look over most or all of the screen (turn the color all the way down and stand back at least 10 feet and look at it,
Changing Glycol involves some important things---this stuff is like antifreeze bit ten times more toxic.
If you find yellow and want to know what is really involved respond to this posting and I will assist you.
If this information told you something you did not know, rate this solution as I do this here for free.
SD TECH
Aug 16, 2010 | Philips Magnavox 9P6034C 60" Rear...
Ok i have a 47in samsung hd tv today it started acting funny the picture and colors arent right like there a blue red and green colors its like the main picture is being copied 3x times once by each color...
this issue is caused by a failure in the convergence ic's and possibly a bad resistor and fuse in the circuit if you need instrution on how to change I may be able to help though it is kinda tech heavy
Jan 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
When I use the HD input on my mitsubishi, everything on the screen is green???
When your picture has a green shade to it when connected through component video cables(red,blue,green) that indicates that you have the red and blue switched around at one end, since you have a picture, that indicates that the green cable is hooked up correctly, if the picture color isn't corrected after you make the switch, then make sure you don't have a bad cable.(it happens more often than you think) Good luck !
Jan 05, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Green & red tint
Most likely nothing you can do to fix this. CRT TVs use 3 colors to make an image on the screen (Red, Green, and Blue). If you're only seeing red and green then chances are the blue has stopped working. You can replace certain parts in the TV but for a 27" TV you'll probably end up paying more for the repair than a new TV.
I don't recommend taking the cover off and trying to fix TV yourself without training. CRTs have a lot of electricity stored in them (even after turned off) and you could accidentally electrocute yourself.
Apr 06, 2009 | Daewoo DTQ-27S5FC 27" TV
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
The red, blue, and green are all out of alignment. HELP!
Sounds like the guns are out of alignment. This isn't normally something that a user can adjust.
Has the television been dropped/jarred or moved recently?
If the TV has a manual degauss function, you can try that (assuming it's really a CRT). Otherwise unplug it from the wall for a half hour, then plug it back in and see if anything has changed.
Apr 07, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
