Question about HTC Touch Viva Cell Phone
My htc touch viva is booting but not loading the os, only a blank screen with the top taskbar, tried hard reset but no luck. was working fine until i soft reset after installing an app.
Actually I only hard reset the device by pressing the reset button at the back along with the action button and the down on the volume button, at the same time. The problem was not immediately solved then, but I left the device on overnight and to my surprise it was fully functional again.
Posted on Oct 05, 2009
How can i formate htc touch viva
do these steps:
Remove the back cover and then pull out the stylus.
2. With the device turned on, press and hold the TALK/SEND and END buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the TALK/SEND and END buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press Send to restore manufacturer default, or press other keys to cancel.
4. Release the TALK/SEND and END buttons, then press the TALK/SEND button to perform the hard reset, or press any other button to cancel the reset.
Jan 18, 2011 | HTC Touch Viva Cell Phone
I have a laptop that i tried to format and not able to boot or install OS again. so i've removed the notebook HDD and connect to other PC via usb cable. but then i'm not able to install OS on that from...
have you tried to set the BIOS boot sequence first priority(ODD) of your laptop?
try this
1. restart the system and while screen is turning on keep on pressing F2 then look on boot then the 1st should be ODD then once you did that press F10 to save and exit then try it again by rebooting system then press F12 while screen is turning on to install OS in you laptop
Oct 06, 2010 | HTC Touch Viva Cell Phone
Hi, im using my htc touch bviva from past a year i dint had any problem till date but from past 2 days my touchflo stopped working my cell phona is working fine only problem with the user...
Turn of your phone and remove the battery for 10 minutes. The reinsert the battery and deploy the HARD RESET ( Check HTC Viva Manual how to do hard reset). Also you may try to clear storage in the settings. BY doing this your device will reset to orginal factory settings.... BE SURE TO BACK UP YOUR DEVICE before starting this... you can use SPRITE BACK UP also available on the HTC website.. download both device and PC software ... take back on PC for easy restore.
Good Luck..
Aug 22, 2010 | HTC Touch Viva Cell Phone
Hi my htc touch viva is seized up. what can I do if nothing moves on the screen?
try restarting it.... if still frozen ... open the back cover and remove the battery... replace it after 10 minutes.... start the phone.. if all is ok then fine else you can soft reset the phone ...if still not working then hard reset the phone...before you try anything back up your phone....check the manual to know how.
Aug 08, 2010 | HTC Touch Viva Cell Phone
Touch screen not working at all on my htc touch viva
You can back up the phone and perform a hard reset as shown in the manual... the manual is available on the HTC website. ensure you download the right one..
May 09, 2010 | HTC Touch Viva Cell Phone
For format htc viva
To perform a hard reset (format)
1. Remove the back cover and then pull out the stylus.
Feb 27, 2010 | HTC Touch Pro Smartphone
Is HTC Touch Viva T2223 upgradable to WM 6.5?
yes it is, but you cannot upgrade it to the new upcoming 7.1
Jan 17, 2010 | HTC Touch Viva Cell Phone
Touch pro screen blank
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
Good Day My yourtube application is no longer working on my HTC Touch Viva when ever I try to load the app I receive a message saying error connection please let me know what caused this.
Dear FixYa Staff
I fixed the problem by simply performing a Hard Reset of the Phone as indicaded in the phones operations manual. The phone was reset to its original factory settings and the problem was solved. However, I dont recommend doing this until you have already backedup your information on you PC.
Have a good day.
kendal_ritchie
Feb 18, 2009 | HTC Touch Viva Cell Phone
HTC Touch Viva Cell Phone Logo
271 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
