Question about Fuji Finepix S6500FD Digital Camera
Nothing comes up in capture mode
Hey
I have a fujifilm S6500fd and i can turn it on to view the pictures on my memory card but when i switch it round to take a photo it goes blank an none of the buttons work - everything works fine except when in the mode to take a picture.
When i turn the camera straight to the capture mode the noise it used to make still sounds but there is nothing after that.
Please help
Fujifilm finepix s2900
If the pictures are in the camera's internal memory, first copy them to the memory card using the Copy command in the Playback menu. See page 89 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s2800hd_manual_01.pdf
To download the pictures from the memory card to your computer, take the memory card out of your camera and put it into a card reader attached or built-in to your computer. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Oct 21, 2013 | FUJIFILM Cameras
How to recover deleted pictures
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Sep 04, 2012 | FUJIFILM FinePix AV100 Digital Camera
Camera won't download to pc
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Apr 20, 2012 | Fuji Cameras
How can i get photos from my Internal memory to my S.D. card? can't see an option on the menu and can't view photos from the internal memory whilst there's the memory card in it.
Put the card in the camera. Press the Playback button (right-pointing triangle). Yes, you won't see any pictures from the internal memory with the card in. Press MENU/OK to bring up the playback menu. Use cursor-up/down to highlight "Copy" and press cursor-right. Press cursor-up/down to select "INTERNAL MEMORY TO CARD" and press cursor-right. Select the desired option and press MENU/OK.
Full details are in the "Copy" subsection of "The Playback Menu" section of the manual (page 70 in my copy). If you need a manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_av100_manual_01.pdf
Sep 13, 2011 | FUJIFILM FinePix AV100 Digital Camera
Camera: Panasonic Lumix DMC-FT1 Problem: Camera is not saving photos Hi, my camera started responding very slugglishly yesterday. I took a few pictures, and some of them wouldn't save. If I tried to switch...
Are you formatting the card in the camera as you're supposed to? Have you tried going into the menu and finding "reset" and followed the on-screen instructions? Do you have photos on the internal memory? If so, remove your card and format the camera to erase the memory.
Mar 03, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
When I turn the camera on, the view finder is blank or black. When I click to take a picture, it goes through the motions, but the picture is blank/black. I can view my saved photos on the memory card...
Sounds like a bad CCD sensor. I've seen the same problem in several brands of digital cameras (Canon & Sony). Better off replacing rather than repairing.
Nov 05, 2009 | Olympus SP-310 Digital Camera
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
My memory card on my camera say it is protected
you look on the memory card, there will be a lock slider thing,it might be on lock , check it,
Aug 17, 2009 | Nikon Coolpix S210 Digital Camera
Can't delete photos
Turn the camera off and remove the memory card. Turn the camera back on and now you should be able to remove the pictures stored in the internal memory.
Dec 03, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji Finepix S6500FD Digital Camera Logo
73 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
